I have a Micro sd 2 gb memory card for donwloading music for my cellphone. I have a reader made by Targus but it has 4 slots on it and I do not know which fits because the slots are all big. I was told that this was the right reader for the memory card.
hello there are two way u can do that, get a usb card reader and follow any of this process
1. put the micro sd card into the card reader and plug it to your computer then your system will see the card automatically, then open your window media player and the player will detect the card and you will synchronise musics from your windows media player libery to the card.
2. you can copy the music direct from your music folder in your computer and paste it on the micro sd card.
The original Blackjack will not recognize anything larger than 2gb. Sorry, but you just wasted buying those 4 gb. cards. I found this out the hard way too when I bought my daughter a 4gb card for her Blackjack. I have a BJ2 which will recognize the 4gb cards.
I speant Hours swearing at my phone because it would not read my music
files, Tried the card on many different phones which would take Micro SD
and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro
sd card in that and then putting your music files into the "sounds"
folder works.
Instructions.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds
folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents,
Sounds, others and Videos on your Micro SD card. Format the card by
going My computer, Right click the Card reader (with you Micro sd card
inserted) and click format. Takes a few seconds. Insert the card into
the phone, the phone will auto put the folders on the card. Then go to
step 1 (above) and start again.
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
You may have to get a card reader that takes stuff off and puts stuff on the sd card that connects to the computer using a usb port because most computers do not have an area where you can insert the micro sd card.
omg... put your memory card with the bigger card witch you get when buying a memory card into the computer. i do everything with usb but if you cant then do it this way
You have to format your micro SD memory card with your phone first before you can download files to it. With the micro SD memory card in your phone. 1)go to menu 2) go to settings & tools 3)go to memory 4)select card memory 5)***SELECT OPTIONS*** ---this will ask you if you want to format your card select YES, if there is a phone password it would be your last 4 digits of your number.
Now eject the memory card from you phone. Now when you put the memory card to your computer you should see the sub menus...my pics..my videos...my music...my sounds. Now all you have to do is just click and drag your music and photos to these folders.
Then when you add the memory card to your phone it will see all the music, photos, etc...
