SOURCE: APC Smart-UPS 1500VA
yeppers...those APC units sometimes kick the monitoring software. sometimes you need to unhook the connection cables(like a reset) so that the firmware can 'unlock' which can cause that christmas tree effect on the panel lights.
SOURCE: APC UPS no power
The unit might have a dead battery, blow fuse, or a bad board.
Your best bet is to talk to an APC rep. Worst case, APC has a trade in program, and can give you a discount on a new one.
Good luck.
Try Chatting with an APC Support agent online.
Here is their direct link:
http://www.apc.com/support/chat.cfm
Chat with a Support Agent
Chat with Support for immediate assistance with your APC Back-UPS, Cable, Surge Protection, Notebook and Mobile Device accessories and products. Agents are available Monday through Friday from 8:00 a.m. to 8:00 p.m.
SOURCE: APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
SOURCE: apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
SOURCE: APC will not stop making noise even after I
Plug it back in and then turn the switch off before unplugging... It thinks you have a power failure when you unoplugged it.
