Question about Invacare Supply Group Invacare Lynx Large 4 Scooter
Scooter moves approx 10 feet then stops led flashes 8 times then stops
Neil Wood
  • 177 Answers
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
Posted on May 28, 2010
How do I charge a moxie power scooter??
  • Turn the scooter's power switch to the OFF position.
  • Connect the charger's plug to the charging port on the scooter.
  • Plug the charger's power cable into a power outlet.
  • When the charger's LED red/orange light is on, the battery is charging. Optimal charging time is 6 to 8 hours, or up to 10 hours to achieve a complete charge. The scooter manual will have the exact charging
  • Times recommended for your scooter.
  • Stop charging when the LED light is completely green.
  • Disconnect charger from the scooter, then from the power outlet.
  • Run your scooter before riding it to verify the battery charge.
Feb 02, 2016 | Health & Beauty
My scooter wont go all of a sudden and the red light on the console is blinking a sequence of 4 times
Amigo Scooter Oxygen Tank Holder Light flash key turned ...
www.fixya.com > ... > Amigo > Amigo Scooter Oxygen Tank Holder
... key on my phoenix 3 scooter the red light flashes 5 times and the scooter will ...scooter wont move,although on the little speedo there is a red light flashing on ... ...light is flashing when the key is turned on. the scooter does not move at all ... flash up and down the console light and you at this point have to turn the key off ...
My pharmore wizard diagnostic light flashes 9 times and my ...
www.fixya.com/.../t25197681-pharmore_wizard_diagnostic_light_flashe...
Oct 8, 2014 - my pharmore wizard diagnostic light flashes 9 times and my scooterdoes not go, can someone help me please - Mobility Scooters question. ... Have no manual for pharmore 4 wheeled wizzard light on but wont move ... Why did it stop working suddenly and is blinking console light in 5-blink sequence?
Jan 31, 2016 | Video Game Consoles & Games
Pride celebrity x scooter flashes 6 times and s ometimes 5 times
hi, they are good readings, the brake resistance is a bit low...however does the brake click when moving the throttle lever to go forward or backwards ?
if the brake is not releasing the scooter will never move...
does the throttle lever feel loose ? you need to convince yourself that the throttle part is working correctly , if you double checked everything including the brake and connectors then we need to look at the controller ..
I do offer a free testing service...
Regards
Rob
Aug 24, 2015 | Pride Celebrity X 4-Wheel Electric Scooter...
Hi moves foeward & reverse approx 6 feet stops dead ?
It can be any number of things.
1. Batteries are bad. Just because they are new, does not make them good or batteries you placed in the scooter are a lower (a.h.) than what is recommended by manufacturer.
2. short in the front/rear harness.
3. short in console.
4. park brake issue.
5. Thermal rollback.
It is an issue that a Technician should look at.
Aug 29, 2014 | Pride Mobility Hurricane Personal Mobility...
Work all days yesterday, this morning went out to van, got to work and it would not move, lights come on flash but will not move
The code 6 failure code is the toggle throttle [engager] isn't in the neutral position when power is applied to the scooter. If the engager doesn't return to the neutral position as soon as you turn the key on the scooter would start to move, that woul
Engager
1. Check connections on red, white and black wires at crimps and soldered joints. (Flash Code
7)
2. Use meter to check for:
- White & Red: 5k1 + 10%
- Red & Black: 2.5k1 (approx.)
- White & Black: 2.5k1 (approx.)
3. With meter between Red & Black, squeeze engager forward. Resistance should go from 2.5k
down to 01 smoothly.
4. With meter between White & Black, squeeze engager reverse. Resistance should go from
2.5k down to 0 1 smoothly.
5. Check voltages (with key on):
- Forward - Red- 4.5V + .1V
- Neutral - Black- 2.5V + 0.1V
- Reverse - White - .5V +.1V
If using a Test Harness - White & Red: 5k, Forward - Red & Brown: 2-5k, Reverse - White &
Brown: 2-5k.
1. Use Red & Brown squeeze engager slowly forward 25 down to 0 slowly.
2. Use White & Brown squeeze engager slowly reverse 25 down to 0 slowly. Make sure dial
speed is set to10.
Jul 25, 2012 | Pride Jazzy Select Gt Scooter
Scooter battery shows full charge but scooter does not move ! red led light flashes 8 times !
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair [email protected] 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 12, 2010 | Golden Technologies Liteway 3/4 Wheel...
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Invacare Supply Group Invacare Lynx Large 4 Scooter Logo
547 people viewed this question
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Lawrence Oravetz
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
