Konica Minolta magicolor 5430 DL Laser Printer Logo
A
Anonymous Posted on May 21, 2010
I changed my trans roller on a magicolor 5440DL printer but the message 'trans. Roller low' is still appearing on the screen have i installed it incorrectly?
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 39 Answers
  • Posted on May 27, 2010
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
39
Questions
0
Helped
11393
Points
52
You can reset the transfer roller counter under the menu for the printer. To do this:
1. Press menu.
2. Push the right arrow twice to get to "Engine"
3. Verify Engine is the option displayed and press select/enter.
4. Scroll through the menu until you see "Engine Service". Press select.
5. Scroll to "Reset Counter Transfer Roller". Press select.
After pressing Select on step 5 it appears to run a calibration (at least it did on mine.) But the message should be gone after that. The counter for the transfer belt is also here. Please be sure not to reset the wrong one.
I hope I've done a good job answering your question. If you have any additional questions I will do my best to answer them. If my answer was helpful for you I'd appreciate a 5 thumbs up rating, or a click on the yes this was helpful button. Thank you!
Error message 0094 after change drum unit
2 transfer roller issue open the located across from the transfer belt sponge looking roller check it
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
What does trans roller low mean
The transfer roller is near the end of life; you need to prepare a new transfer roller. The printer will tell you when by changing the message to trans. roller end. The directions start on page 76 of the user's guide. http://printer.konicaminolta.com/support/current_printers/mc5440dl_sup.htm for the PDF You'll need to reset the counter as well when you insert the new roller. Other consumables may also be nearing the end of life (like the transfer unit itself). The manual has details for checking their status. Get the appropriate parts from the company (or a third-party vendor).
I hope this helps.
1helpful
SERVICE CALL 14 XFER ROLLER Have installed new transfer belt. Still had error message. Came here and read tips. Cleaned the sensor both in the printer and on the transfer belt; reinstalled. Still...
the transfer roller is a foam roller that transfers the toner onto the paper. It will be visible with toner removed, a little wider than a piece of paper, and about the thickness of a roll of quarters. I don't know how to physically remove it on your model, but transfer roller issues in general can be remedied by removing the transfer roller and wrapping it in packing tape until the tape comes off clean.
While you're in there, vacuum everything out for good measure; but never, ever use canned air on a laser printer.
Konica minolta MEDIA JAM TRANSFER ROLLER
yes 2 things. 1 bad sensor. 2 bad paper. change paper brand and type. use hammil mill 20# long grain brightness90 and above to test. if this works you need better paper. if not you have a bad jam sensor and need a tech to repair ir.
Magicolor 5440dl manual feed jams paper as it feeds into printer. paper gets about half way. paper is not smashed or crinkled.
If the paper was damaged we can presume that there is a blockage, however your jam sounds like the paper is not in the expected position at the expected time (ie a sensor is not reporting that a peice of paper has reached it) so this can be cased by
1. rollers slipping on the paper from
a/ slippy media - try a different paper (even as a test)
b/Build up of paper dust on the rollers- If you can see the roller, power off and wipe with cloth
c/ Roller ware - If you can see the roller and have a mild abreahisive like wire woll If you can see the roller and give the rollers a rub
2. Sensor failure-Try Powering off then unplug wait 2 minutes and then power back up, this will reinitilise a sensor
Konica minolta magicolor 5440dl
I'm assuming these are Black lines?
1-check the fuser, the part where it exits and gets HOT,
the rollers must be shiny and clean, if the coating is starting to wear off it retains some toner on it causing lines or copy quality issues.
Faded left hand copies
Pleas check that you inserted the K toner correctly, check, that transfer belt and/or drum cartridge is installed correctli. also check that 2transfer roller, its one big black roller.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
