Samsung SyncMaster 920NW Monitor Logo
Posted on May 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Monitor comes on for 2 seconds then goes blank
Monitor was working fine. I used the windows control panel to remove some old programs. I deleted only old games or programs I no longer wanted. After I was done, I rebooted the computer. the monitor pops on for just a second or two then goes blank. If I turn the monitor's power button OFF then ON, it, once again, comes on for a second or two then goes blank.
The computer seems to be working fine.
Anonymous
Level 3:
  • Master 1,138 Answers
  • Posted on May 23, 2010
Anonymous
Master
Level 3:
Answers
1138
Questions
Helped
432528
Points
3620
Check if the cable connecting your monitor from the video card is properly secure and not loose...
You can also try this... turn off your cpu..remove the cable from your video card.....Open the housing....remove your video card from your motherboard... clean the contact surface of the video card with moisten cloth.... after cleaning...connect the video card to the motherboard...attached the cable to your video card.. close the housing and try to boot again...
I hope that work.. if not my suggestion is you try your video card in other computer, try also the monitor to other computer.. to see which one failed.
Much appreciated if you rate this help.. thanks..
  • taenyo181 Jan 13, 2011
    hi. im havent tried this method, but i tried opening the monitor with the cable unplugged in the cpu. im expecting to see a "no signal" display on it since it was not connected to the videocard(or in the pc itself) but same result, after turning it off then turned ON, it open then after few secs turned black again...
Saeid
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 84 Answers
  • Posted on Jan 21, 2015
Saeid
Expert
Level 2:
New Friend:
Cheetah:
Answers
84
Questions
Helped
53078
Points
143
It's an LCD so the problem is most likely the back-light inverter board. Take a flashlight and shine it directly into the screen from the front. Can you see the image on the screen now? If the image is there but you can't see it without the flashlight than the inverter board needs to be replaced. This is a VERY common problem. Good Luck and let me know what happens, His Dudeness
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 07, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1735
Points
Hy am experiencing the same same problem my monitor comes on for 2 seconds then goes blank I tried it on different pc's but it does the same thing I checked its power supply and capacitors but none looks to have busted or burnt I went to a technician and he told me its the ( ic ) whatever that is he asked me to pay R400 is that a fair price to get it fixed
0794560147 or bbm 26A21C27 pls help
I entered the problem before. Here it is again:
In the Control Panel>Accessibility>Display
If the high contrast box is checked, uncheck it.
When you say in "Add program", where is that exactly? Under Display in the Accessibility window I only see High Contrast Options andCursor Options. Did you maybe change a program in the Control Panels "Add or Remove Programs" section? It's either that
or
your monitor may be entering power saving mode.
This problem could be that your Power Options in the Control Panel have been switched to "switch off the component ever now and then to save power". To change this, do the following:
1) Navigate to the Control Panel by clicking Start and then Control Panel. Then double click on Power Options as shown below circled in red.
2) This will then display the Power Options window as shown below.
3) Once you have opened the Power Option Properties, under Power Schemes select the one that best suits your PC system.
4) Then you can select whether or not to switch off your monitor and/or hard drives after a period of time when it is not being used.
If you have your PC on most of the time then I suggest you select Never as the turn off option for both your hard drive and monitor. If you are using a laptop the turning off the hard drive and screen can however save on battery power when the laptop is not in use.
If your problem persists then it might just be as simple as a loose connection, make sure that your monitor display plug is correctly plugged into your display card or onboard display correctly.
Let me know how it goes.
~Slasher_X
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Dual Monitors. #1 works fine. Plug inb #2 and #1 goes to sceeen saver and #2 stays blank.
Both monitors must be plugged in when the computer is started for the second monitor to be detected, and you must configure the second monitor once the computer has started
In windows XP: control panel -> display -> settings tab -> select second display -> check "extend my windows desktop onto this monitor" -> click apply
In windows vista/7: control panel -> adjust screen resolution -> select second display and then under "multiple displays" select "Extend desktop to this display"
4answers
How to remove msn
I take it that you don't wish to use MSN for internet access. You can delete it from your network connections window.
Then you will have to set up a connection that will use either dial-up or some form of high-speed connection. That will become your default connection.
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
1helpful
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Blank monitor
To resolve the problem,do the following step,
1. Power on the system
2. At dell logo screen before windows xp starts to load tap on the F8 key slowly 5 to 8 times
3. Select safe mode
4 Hit enter on the next screen and logon using the administrator or your name
5. Do the system restore, when you have logged on, this would return your system back to the date when it was working fine
6. To system restore
click start>all programs>accessories>system tools >system restore
Thanks
proton
1helpful
X191w blank screen after 2 seconds
Just got off the phone with Acer Suppport. This was after I sent an email to them, that suggested that I call. 8-/ annoying. So the guy on the phone says there is one thing that we can do before sending it in. Unplug it completely for the wall and computer. Hold the on/off button in for 30 secs. reconnect power and the computer. It worked for me
SCREEN GOES BLANK
Hi.
I have have repaird a few monitors, the acer one was the back light, but it was I think 7 capacitors, they were old, aged, and stopping the light from working.
So, get it apart, and replace ALL the caps, they are not expensive, do not touch the parts when powered up, it is high voltage, and will probably hurt you whilst killing you, so, DONT TOUCH!
Check out web for any other help, lots of videos to show you how to proceed.
Ray.
1helpful
Blank after 2 seconds
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
