Question about Sony Handycam DCR-DVD201E DVD Camcorder
My LCD Screen has gone white and I have tried many things but it stays white. What should I do?
Posted by rhonabain on
David Webb
    Sergeant:
  • 338 Answers
Wow, only ever seen a case like this once, maybe not same reason as your case, but the one I saw was damaged by having something bright eg sunlight directed into it's iris (camera lens) and it took out the auto light sensor part which made everything look like a burn-out, maybe pop in in to a Jesops camera shop if you are near one, see what they have to say about repair.
Posted on May 23, 2010
When I turn my camera on there's just a white screen and no matter what I press the white screen stays
The lcd has either gone bad or has worked its way loose some how. The camera needs to be taken apart and have the lcd ribbon examined. Try this first, it should be a ribbon with a clip, if this is in place the lcd is bad and needs to be replaced, look at ebay or amazon for a replacement LCD for your camera make and model, most are around $20 and easy to replace.
May 05, 2011 | Cameras
Screen has gone white when I turn it on. It is still receiving input from my cable box, and I can hear the show being broadcast, but the screen is white. I can not access the menu on the TV to see if it...
your T-con board has failed you need to have a tech take a look because there are so many differant lcd panels use in the same model he or she will have to do the rearch inside the set by getting the genaric number off the lcd panel
Dec 07, 2009 | Samsung LN-T1953H 19 in. LCD HDTV
Why is my se w810i coming on with a white screen?
That white screen means that your phone needs to flash over you will need to download xs++ to do so if you need any help email me
Thank you
God bless
Aug 10, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Same thing
The white screen could indicate a bad inverter or the screen itself.The screen staying black could mean the video card has gone out.
Jul 28, 2009 | Acer Aspire 5670 Notebook
W810i can switch on but blank screen
May be video display chip has got damaged.
You need to replace it through any authorized service center.
Jul 09, 2009 | Sony Ericsson Walkman W810i Cellular Phone
The phone screen has gone white, i can't see anything...
your phone lcd need to replacing.in some cases connectors have problem,it must test with a new lcd & then problem will solve.
Jun 04, 2009 | Nokia N70 Cellular Phone
My w810i phone shows up a white screen..my phone is 1.3 yrs old...i am unable to do anything..please help me...in this in concern..thanks in advance...!!
If your computer recognizes your phone when you plug it in, you may have a problem with the lcd screen.
When my Sony W810i had the white screen problem, I was about to buy a new phone when I found out about the Sony Ericsson Update Service (SEUS). I used it to fix the firmware inside my phone, even though the phone seemed dead and my computer wouldn't recognize it. You can download the SEUS from Sony's website here:
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w810i?lc=en&cc=us
Mar 15, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Black/white/rainbow screen
Sounds like power board issues, if your able test the voltages coming out of it and see if they are correct
Nov 23, 2017 | Insignia 19 in. Widescreen Flat-Panel LCD...
Zen screen stays white
The white screen of death is due to a hardware failure in the LCD screen and the only way to fix it is to replace the screen itself. You can find a screen and repair services at www.TheGadgetDr.com
Aug 13, 2008 | Creative Labs Zen Digital Media Player
Constant white screen
check the brightness and contrast from the menu on the monitor try increasing it ... the problem will get solved...
if same problem persists contact ur near by experrt technician he may tell that the tube is gone he must recharge it....
Sep 11, 2006 | Sony SDM-HS73P 17" LCD Monitor
Sony Handycam DCR-DVD201E DVD Camcorder Logo
111 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Al Rush
Ekse
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
