We have just unpacked our lay z spa after storing it in a warm dry place for the winter, it worked fine last year but there seems to be a problem now. When we switch it on the displays shows 22/23 degrees as normal then after a couple of seconds the dispaly shows 3 dashes and the heater light flashes. From this point it will not do anything?
SOURCE: We have refiled our lay z sap, after it dispaly shows 3 dashes
You probally just need to break an air lock in the pipes. You can ether force water down the skimmer pipe or find your drain valve and open it for a minute or two till it runs just water and no air. This will get water to the pump and the heater. This should fix you up.
