Question about Casio BabyG Shock Resistant #BG905B Watch for Women
CASIO Baby G Shock Watch BG905B cannot turn off hourly beeps. I want to turn off all alarms and beeps
Posted by the_kirbys on
David Tolond
    President:
  • 2,501 Answers
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on May 23, 2010
How to turn off hourly beep on a casio watch
I have the answer how to stop the hourly beeping on watch f91w you press c button on left bottom and right button at same time as pressing left bottom button and that will remove the alarm pic at top and it will then turn off the hourly beeping. About the watch f91w.
Jan 13, 2011 | Casio A168W Wrist Watch
How can unmute my watch. even the alarm tone is on mute.
Um, well I had the same problem on my baby-g watch, but i fixed it so here:
- dunno if this'll work, but hold the bottom left button for a long time. never let go till you here a beeping noise. like DO NOT let go. like this is a g-shock and not a baby-g, i dunno where the mute is indicated, but u might see it somewhere. so, just do that dunno if it works as, again, i have a baby-g. good luck! :)
Nov 30, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Oct 01, 2010 | Casio G-Shock G2600 watch
How to turn off alarm on g-shock casio watch
watches;
Accept terms
Apr 18, 2010 | Casio G-Shock GW500A-1V Wrist Watch
Can't shut off beep going off every hour
Hold down all four buttons to reset the watch. My time didn't reset but the beeping FINALLY stopped.
Mar 01, 2009 | Casio G-Shock G510D-1AV Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
Jul 05, 2008 | Casio G-Shock G2600 watch
Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Mar 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio BabyG Shock Resistant #BG905B Watch for Women Logo
Top Casio Watches Experts
Bruce Robin
k24674
Resolution IT Dubai
Resolution IT Dubai
Are you a Casio Watch Expert? Answer questions, earn points and help others
