The left front speaker output does not work (neither for setting A or B) whereas the right front speaker, center, subwoofer, and surround sound outputs work normally. All other receiver functions work perfectly. The speaker itself and connections are not the problem. Is there a RESET that I should do to try to fix the receiver or is it definitely a hardware problem? Any simple fix idea that I may be able to do? Any idea what the problem is...and any idea what it will cost--I am wondering if it would be less expensive to purchase a new receiver? Thanks, Aaron
Does the speaker setup fail the same way?
Yes? Internal amplifier problem.
If No - What source(s) do this?
If just one - reverse its Left and Right inputs to determine which cable or channel on the input device is faulty.
Testimonial: "Seemed to understand the problem and gave a couple of possible causes based on certain variables. "
