Question about Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas
Teledyne laars series 2 pool heater pilot is on,gas is on,switch is on,pump is on,water flowing to pool,replaced thermocouple, and heater wont kick on. thermostat is set. what am i missing. Is there supposed to be power to the unit? I was told that there was no power needed. sounds strange considering that there are wires involved. where does power hook up if needed?
Posted by rjmabarrett on
Muzahura Frank
  • 2,069 Answers
First of all, I'm assuming that your heater has a pilot and not self ignition.You will need a jumper wire ( 16" of wire with an alligator clip on each end)attach one end to the terminal on the gas valve that the red wire from the pilot generator is connected to ( pilot gen. is the thing the pilot flame touches).
Now attach the other end of the jumper to the terminal where the wire from the connects to the knob where you set the water temp).
NOTE:
JUMPING BYPASSES ALL BUILT IN SAFETY DEVICES AND IS FOR TEST LEAVE THE JUMPER CONNECTED TO RUN THE HEATER FOR HEATING PURPOSES!!!!
Posted on May 22, 2010
  • rjmabarrett May 22, 2010
    attach other end pf jumper to terminal where the wire from "what" connects to knob to set water temp. you didn't say where the other wire is connected.
  • Muzahura Frank May 22, 2010
    run a wire from terminal on lighting assembly to high limit switch on top right of the heater.
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
Pool heater stays lit for approx. 30 seconds then shuts off. pilot stays lit whole time but burners wont stay lit. water flow is good
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Pilot comes on but no gas flow.
Hello. you need to replace the thermocouple which is a safety device that turns the gas on and off. Joe
please rate my answer as very helpful. Thanks.
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
Teledyne Laars Laars Lite 2 Pool Heater 325,000 Btu / Propane Gas  Logo
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Oloyede Monsuru
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
