Question about Toro Lawnmower 20099 Mower Mowers Lawn
Fuel feed Ive cleaned the carburator, changed the plug, air filter, but it just won't take off. It will chug-a chug-achug then die. It wants to go but acts like it is not getting fuel. This is a toro self propelled, walk behind model 20017
Posted by johnjoyce18 on
Michael howard
    New Friend:
  • 177 Answers
Carby service 1 of the brass pipes or jets are blocked ,your looking for a minute pin hole so good luck usually a jet has 4 holes look for one near the thead
Posted on Jun 11, 2010
Chugs when driving at rpms around 1300 when accerating
Start with checking fuel pressure. Pressure must be at specs before looking elsewhere, like spark plug condition, air filter, air or vacuum leaks, throttle position sensor, etc.
Dec 31, 2015 | Cars & Trucks
18.5 briggs intek vtwin only runs choke on only
Make sure the fuel jet is clean. Its easy to miss when cleaning the carb. Ive seen a lot of dirty fuel jets that once I clean them out run like new after.
Sep 25, 2014 | Garden
99 Ford Windstar 3.8l miss fire on cylinder #2 and lean on bank #1. I changed plugs,wires,and coil. Still miss firing and chugging! Someone help me please.
Have you checked your fuel pressure ,Changed your fuel filter, and last of all , Ignition module... free check at Autozone, Advance, Napa,
The chugging- clean out or replace your IAC valve, Idle Air control valve...
Aug 08, 2014 | Cars & Trucks
Engine chugs then dies
Hi Anonymous, and the usual suspects are:
1. Battery terminals loose, corroded, or broken. Check negative cable at both ends.
2. Battery nearly discharged.
3. Faulty or corroded Maxi fuse, system relay, starter relay, circuit breakers and fuses.
4. Faulty ignition coil, ignition/electronic module, CKP, CMP, MAP and BAS sensor.
5. Pin or spade connectors corroeded, melted, broken or pushed back.
6. Intermittant short circuit due to damaged wire insulation.
7. Loose or dirty ignition/electronic module at crankcase.
8. Water or dirt in carburator or fuel system.
9. Faulty fuel pump, pick up tube, pressure regulator or fuel filter.
10. Fuel tank vent system plugged or carburator vent line closed off.
Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 18, 2014 | Harley Davidson Motorcycles
Hi i have a 4stroke 125cc pit bike it wont start tried bump start sorted turned over but when i reved it didnt respond then died any ideas
Tryd go to auto shop and check the carburator of your motor and clean your air filter adjust air setting in carburator and put a new fuel pump check fuel setting in carburator
Jan 18, 2014 | Motorcycles
My 1991 olds mobile cutlass calais wont start,after I added fuel injector cleaner because,the car was having hesistating problems below 25 miles an hour and it might of been a spark plug problem or fuel...
When you chaged the air filter & sprayed Gumout carb cleaner, you got rid of a little gunk in the
air intake, but when you added the fuel injector cleaner (its the same stuff as carburator cleaner) to the fuel tank, you "cleaned out" ALL the ****/gunk/buildup/dirt in the fuel system which has built up since 1991 and sent it straight to the fuel filter, which is now clogged. The reason that the car tries to start, but fails, is that it'll successfully burn up any fuel that gets past the clogged fuel filter, but the engine consumes that small amount of gasoline quickly, then dies.
Your solution: change the fuel filter.
The fuel filter is located:
Under vehicle, driver side, below seating area, near fuel tank, mounted on frame rail in fuel line
Sep 30, 2011 | 1991 Oldsmobile Cutlass Calais
I stored the bike over the winter with a full tank of fuel in it it fires up but wants to die after i push in the choke,it just will not idle it wants to die out unless i keep cracking the throttle
Clean air filter,Change out fuel for fresh fuel.Check plugs and gap on plugs.You may even have to take off and clean carburator and fuel bowl.
Apr 12, 2011 | 2001 Yamaha V Star Custom
My truck starts fine but dies after about 2-3 min when I let off the acclerator and come to a stop. It runs a little rough when I accelerate, I've changed the plugs,wires, air filter, & distributor cap...
yes please replace the fuel filter,the fuel filter replace every 40,000 kilometers according to the factory specifacation.then buy a repair kit of the carburator to clean and replace gasket to prevent leaking of gasoline
Mar 17, 2011 | 1990 GMC Sierra
R1150rt. after a fuel stop it died on the road, changed the fuel
Carburator clean up could help solve the problem, it seems some dirt may have entered the float chamber!
Blow the jets with compressed air.
Hope this helps!
Nov 04, 2009 | 2002 BMW R 1150 RT (ABS)
Toro Lawnmower 20099 Mower Mowers Lawn Logo
441 people viewed this question
Top Toro Garden Experts
Dennis Key
Dennis Key
Marvin
Marvin
dannydoesita
Are you a Toro Garden Expert? Answer questions, earn points and help others
