Question about E-Machines T6520 PC Desktop
When playing CD's on my E-machines T6520 I get a clicking sound just like a record with a scratch in it. I took out the CD Player (CD-Master 48E Model SC-148) that came with the computer and replaced it with a HP GCR8482B and installed an updated driver, but I still get the click, click. If I play the disc in the DVD Player it plays fine!
  • 4 more comments
  • Anonymous May 22, 2010
    May 22, 2010
    - The click-click sounds happens with ALL CD's played. Played on another machine there is no clicking. I swapped CD players within the E-machine computer, and the same problem occurs, so it can't be cleaning. It might be a capacitor discharging? Again, the same CD's play fine in opther players. It cannot be the player as I swapped them. Any other solutions?
    May 22, 2010
    - Jimmy:
    In comparing the sound of the CD Player and the sound of the same disc when played in the DVD player, it is quite obvious that the CD is playing SLOWER and has the clicking sound!! Could this be a power supply problem? aGAIN, i SWAPPED cd pLAYERS, BUT THE THE SAME PROBLEM OCCURS.
  • Anonymous May 24, 2010
    Jumah suggested there was a virus! I rescanned with McAfee - there is no virus!
    I swapped the 3 pin power supply cable from DVD to CD Players - no change, so it is not the power supply cable. I then switched the multi-pin cable from DVD to CD and put back in the original Samsung CD Player - no change... I still get click-click, click-click and it sounds like the music is playing slower than when the DVD player is used!
    The screw are tight!
    There is no virus ... the CD and DVD players are in the same computer using all the same systems, and Driver Detective says the drivers are up to date!
  • Anonymous May 25, 2010
    This happens on all disc's! It is NOT the player! I replaced the Samsung with a good HP CD player as stated in previous posts. It is not a mechanical problem otherwise replacing the player would have cured the problem. It is NOT the screws - it is NOT the cables - it is NOT the Speaker Jacks. Again - the speed is off - it runs slower than it should no matter what CD Player I use. I've disconnected the DVD power cord and played the cd with no correction in performance, so it CAN'T be the power supply The problem occurs whether using Windows media Player or Media Center - the DVD Player works fine with these programs. The problem thus is relegated to the motherboard and/or driver.
    You hit it on the head! I was about to give up with all the silly suggestions! I pulled an old PCI Soundboard from an old computer and that did it!
    Much appreciated!
Will Hartford
  • 1,472 Answers
Flogue
The clicking sound is not related to the CD or ROM drive but an issue with you hearing the bus noise through the speakers.
Question if you play an MP3 do you hear the same sound. Note CD-Audio playback is handled differently then playing a DVD. The CD audio signal is still analog so the back ground interference can effect the audio you hear.
If you other audio sources do not have a problem then I would recommend getting and IDE cable with more shielding on it to see if this makes a difference. Another option is if you have an extra SATA connection you might try getting a SATA ROM drive to see if you still have the problem. Also another way to go is to disable the on-board sound card and install a PCI one in the system.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on May 25, 2010
    Issken:
    Now maybe we're getting somewhere! When playing a MP3 disc it plays OK with an occasional clicking in the background! Speed is fine!
    Is the IDE cable you mention the flat multi-pin cable attached to the back of the DVD and CD players that connects to the motherboard? If so, where would I get a shielded one?
    I see 3 or 4 orange plug-ins marked SATA1 through SATA3 - are these the plugs for a SATA CD Player?
  • Will Hartford
    Will Hartford May 25, 2010
    flogue
    So if you are getting noise when playing and MP3 too this is signs that you are having a resource conflict on the system and/or just strong bus noise. The problem with alot of the modern computers is that the manufactures like to put all the devices as onboard devices.
    In regards to the SATA connection the cool thing about them is you can use them for ROM drives and hard drives.
    For the shielded IDE cables you can get them at your local computer store. If you do not have one in your area let me know and I can point you to one on line.
    The other question I had for you is do you have access to a PCI sound card. If you do I would like you to try disabling you onboard sound card and install the PCI one to see if you have the noise problem still.
    Let me kknow if you have any questions or more problems
    Issken
Rishi Roshan Ali
  • 2,427 Answers
The problem isnt your drive.. all the drive does is send the data to the computer.. its the computer in this case that changes the data to the music your hearing.. Now this can be 2 things the first if your audio jack,, its the green one ,, the speakers plug into.. remove your speakers and plug some head phones in instead and listen a few songs to see if the error is gone.. if so change the jack at the end of your audio system.. If not then your issue is the sound card.. Purchase a new one and install it (a cheap one will do),, install drivers plug your system in and listen to your songs..
Posted on May 24, 2010
    Darklord1:
    As I have said - this machine has a DVD and a CD player, both hooked to the same sound system and both playing thru the same speakers! Logic says it cannot be the jack as a jack can't differentiate where the sound is coming from!
  • Rishi Roshan Ali May 25, 2010
    If you open the pc you will notice that the dvd player has a 4 wire jack from the back
    directly to the sound card or mb.. Remove it from the dvd and plug it into the cd drive..
Liza Halbrook
  • 560 Answers
Hi. Is it doing the clicking sound on several disks or just on one particular disk? There some disks that are thicker than normal and some player is having hard time playing the disk. Try a diff disk and if the clicks disappear, the problem is on that particular disk and not your computer's player.
  • Liza Halbrook
    Liza Halbrook May 25, 2010
    I am positive that the problem is with the POWER SUPPLY going to your CD/DVD drive. If you can borrow a power supply unit, try to replace the power supply.
    If you don't have spare power supply, use a different power supply connector from your existing PSU.
Anonymous
  • 493 Answers
The DVD or CD drive is mounted with two crews through each side, and you don't want to skimp, these drives can vibrate like crazy if they aren't secured properly.
Please check them and all the connections again.
You may find the illustration about it in THIS LINK.
Hope this helps.
  • 2 more comments
    Hi again,
    If you installed extra CD/DVD Driver and additional USB Cards, and if you didn't upgrade your power supply this may occur. As you know extra devices needs extra power. Then it may cause such problems. Please check the capacity of your power supply. Test replacing it with another higher capacity.
    Hope this helps.
    Waiting your comments.
    Flogue,
    This link may be helpful for the Power Supply capacity.
    Best wishes
    ioktay
    Dear Joktay:
    No change was made to computer, it's the way it came from the factory. I inherited the computer from a old relative who couldn't operate it. No physical changes were made - the clicking sound has existed from the day I got it.
    Dear Flogue,
    I tried to find a simple solution to your problem.
    But unfortunately it seems to be there is a mechanical fault in the CD Driver. In my opinion it would be better to replace it with a new one. Otherwise it may damage your CDs. It is not a software issue.
    Hope this helps my friend.
    With my best wishes.
    ioktay
Anonymous
    President:
  • 1,561 Answers
The problem is that there is a virus on the system, you will need to scan the system with a license and active anti-virus in other to make sure the system is virus free.
Once the system is virus free, the clicking sound will stop, just make sure you scan your system with a license and active anti-virus to make the system free from virus, this will solve the problem of clicking sound while playing your cd.
Take care.
Posted on May 22, 2010
    You may need to change the IDE cable, try to use another Ide cable because it is possible that the Ide cable could be bad.
    There is NO virus on the system. I ran my Virus Program and ran the McAfee free program. NO virus detected. Why would anyone write a virus to just interfere with a CD player - virus' are written to screw up the world not one computer!
Jignesh Khare
  • 242 Answers
Is it happening for any particular disk? If not then read below.
The speed of DVD drive and CD drive differs a lot.
The balancing between both of them is also differs.
The only thing that i can suggest you here is clean up your CD ROM. Insert the drive cleaner disk and play it, if there is any dust into it then it will be removed.
If the disk is playing in the CD Drive then don't pay attention on it and let it play.
The life for an ordinary CD Drive for computer is not more than 2 years for better result.
Thanks
Jimmy
  • 1 more comment
    Jimmy:
  • Jignesh Khare
    Jignesh Khare May 25, 2010
    This may be a power supply problem too, however it seems more as balancing problem to me.
    Sorry mate i am not much help on here.
    Thanks
    Jimmy
Why will my xbox let me play some games but not other on live when i used to be able to play them all?
Check all X Box games for scratches on the surface of each CD Disk.
Keep in mind, each game CD is read by lens Laser from the inner then to the outer edge of CD Disk.
Most people believe CD's are played like a record, from the outer edge to the inner.
If there are scratches, CD may be damaged beyond simply cleaning.
All cleaners and methods of cleaning are not the same.
Contact the manufacture of the CD to find out the best method of cleaning
or possibly repairing so game can be played.
If you CAN play some games and NOT others, this rules out a Laser Lens Player fault condition. Look for a reason of the CD will not play in the Laser Lens Player.
Here is the top 5 reasons CD's will NOT play.
1.) CD in inserted into player wrong way?.
2.) CD surface is dirty or dusty?.
3.) CD is possibly warped or bent?.
4.) CD surface is scratched?.
5.) Wrong CD/ or format for CD player?.
Hope this lists helps!
FASTESTNASCAR
Jan 01, 2012 | Microsoft Xbox 360 Console
When I try to listen to the cd's, it won't play them. It tries to acknowledge them but the player won't play them
CD players commonly will not recognize some types of CD, eg MP3 recordings, or maybe CD-RW recordings.
However if this is happening with CDs that would previously play OK, then it could be
- scratched or dirty CD surface
- contaminated laser lens in the player
- laser lens has become misaligned
The last 2 need a service technician, but it may be cheaper to buy a new player.
Nov 19, 2011 | Audio Players & Recorders
CD player on Sony ZS-D55 has increasingly bad dropout. We've had this player about 4 or 5 yrs, and it started almost from new. I've cleaned the 'head', the laser eye, with a cotton bud moistened with...
One possibility is that there is a scratch on the CD lens. But first try cleaning again, but this time use Isopropyl Alcohol. As meths might leave residue behind.
May 01, 2017 | Sony PSYC ZS-D55 Cassette/CD Boombox
While playing A cd the sound intermittenly stops like A skip and sound comes back but player is never moved
If the CD is the problem it could be scratched or dirty, clean the CD with a CD Cleaner if need be. If the CD mechanism is the problem the sled assembly may not be moving smoothly or is hindered ( the sled mech moves the laser across the CD like a needle arm move the needle across a record), the laser lens may be dirty also. Use a CD lens cleaner to clean the lens if you can not manually clean it with some lens cleaner and a swab. If the sled mechnism is the problem the unit may need to be taken in for service.
Jun 27, 2010 | Durabrand CD Player with Cassette...
Tascam cd-rw750 - while recording from another CD player (using digital coax connection), machine records for some time and then just "jumps out of record mode" and goes back to the beginning like nothing...
1. First problem: "like nothing is recorded". IS something recorded or has it been left in Pause Mode so long (instead of Recording) that it just got impatient and time out?
2. Get yourself a couple of CD-RW Digital Audio discs to play with until you're past this learning curve/problem scenario. That way you can always erase them and start over without having to discard the disc.
3. Dropouts on playback. Are they repeatable - always at the same place, even on different CD players? If so, the data is bad on the disc. If not, the data is probably marginal.
4. If you have a DVD player, try to play the failed recordings in it. Some DVD players can play back unfinalized CDR's. You may be able to recover the data by copying it back to the CD Recorder from the DVD player. Just be advised that an unfinalized CD-RW may not have 'silence' following the last recorded track due to old data remaining from a previous session, so be ready to pause or stop the recorder when the last track finishes.
5. "Scratches near the outside of the CD". Were these NOT present prior to entering the CD Recorder? Do they seem to coincide with about where the recording may have failed?
6. 20 vs 19 tracks: Is this a constant problem or only when there is a failure during CD creation? If the latter, it would make sense as the last track in isn't technically completed.
Apr 09, 2010 | Tascam CD-RW750 CD Recorder
Have rs480m motherboard need the 2pin sequence to hook up the hard drive ''e-machine t6520''
I assume you are looking to connect another hard drive in your computer.
Most desktop computers have two IDE controllers.
The 1st controller will have the "C" drive set to Master (MA) and there maybe another drive CD or DVD drive on the same IDE cable, if so the drive will be set to Slave (SL) or if you intend to install a drive on this cable.
The 2nd. IDE controller and cable can have hard drive or CD/DVD drives too but the drives must be set to either Master or Slave - BOTH drives in the one cable CANNOT be set the same.
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | E-Machines T6520 PC Desktop
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
Tascam dpo2 not burning a cd
You need to create a master first before you can burn it to a CD.
To create a master you'll need to set an 'OUT' point, then enter mastering mode (by pressing the master key so that it flashes) and then record your master by holding record and pressing play. The master recording stops automatically when it reaches the out point (the in point is always zero). The steps for creating a master are outlined on page 27 of the manual. Setting the in and out points can be found on page 30 and burning the master to CD is on page 67.
Hope this helps.
Cheers.
bd.
Dec 20, 2008 | Tascam DP01 All-In-One Recording Package...
NAD C541i CD Player plays but the sound cuts out for an instant every 10-20 secs. It eventually goes away, but it is annoying when you first play a disc. Any help appreciated.
hi, i've had a few nad C541i's and not so long since the sound on one of them cut out for milliseconds and on some occasions the sound would make the noise very much like a severely scratched vinyl record, i thought it was a faulty laser so i tried another KSS-213C laser out of a scrap kenwood and the fault persisted. to cut a long story short, i took the main PCB out and there were various dry joints. once these were resoldered i was blessed with a fully functioning player. hope this helps?
Nov 16, 2008 | NAD C541 CD Player
Recorded finalized CD's will not play on standard CD player
Are you using the same brand of discs you used to? Do they palyback on the machine in both the record and the playback deck? Do your old cdr's you recorded still play in the standard cd player? You can try the diagnostics - hold down the 'play' and 'fwd' keys on the record side as you power it on.
Oct 31, 2007 | Philips CDR778 2-Disc CD Recorder
E-Machines T6520 PC Desktop Logo
88 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
