Question about Kenmore 63942 Dryer
The unit will run but no heat is generated. I am ...
The unit will run but no heat is generated. I am trying to find a heating element part to replace the old one but am having problems with the sears sight trying to find it. The model number is 68712894 and is not recognized at the sears website. Thanks
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Go to www.Sears.com/parts Your model number was not recognized is because you are missing the first 3 numbers. all Kenmore's start with a 110.. so yours would be 11068712894.. your heater element is in the bulkhead pictures. but be careful if it is not heating it may not be your element.. you have 3 main heat sources your element. and two thermostats one is actually connected to your element and the other is on your heater box which is what you will take your element out of... you can take an OHM meter and test for continuity to see which is not giving you any power. if your reading 0ohms you have found your problem... its usually one of those three. the thermostats are in a kit referred to a thermal cutoff kit. also clean the lint screen and the ducts...
Posted on May 25, 2010
Anonymous
    Genius:
  • 1,122 Answers
Unplug remove back and you can get to everything-mike
Posted on May 22, 2010
3 Related Answers
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore HE4t Dryer - no heat
The usual suspect for a Kenmore HE that runs, but doesn't heat is a thermal cut-out or the thermal fuse. Although they are a bit more resilient, in some cases the heating element itself could be bad. The way to check: 1. UNPLUG THE DRYER, FIRST. 2. Remove the bottom kick plate on the front of the dryer. 3. Remove the blower fan cover directly under the lint screen. There should be a couple of 1/4" screws holding it on. 4. Directly behind the blower fan cover on top of the blower fan housing are two components. One is the operating thermostat, and the white one is a thermal fuse. The fuse is a one-shot fuse that must be replaced if it is bad. 5. To the right is the heating element housing. There are two additional components mounted on the side of the element housing. The component furthest to the back is the thermal fuse. The one one closest to you is the hi-limit thermostat. 6. Check the continuity of thermal fuse and the thermal cut-out. They both should read a short. Additionally, check the resistance of the the heating element. The element should read something low (less than 20 ohms). 7. If the thermal fuse reads open, replace it. If the thermal cut-out is bad, replace the hi-limit thermostat with it. They are usually sold as a set. If the heating element is bad, you will need to disconnect all electrical leads and remove one 1/4" screw holding the element housing to the bottom casing. Pull the entire element housing from the dryer. Depending on model, sometimes the element slide out of the housing, sometimes you will need to remove a few screws to open it up. I hope this helps you.
Posted on May 25, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Dryer doesn't heat
The problem may not be the heating element. The following link explains how to troubleshoot a dryer no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer will exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the washer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum. All Kenmore dryers are not constructed the the same. Regardles of location, the Heating Element is located inside the heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals. If either the TCO or Hi-Limit Thermostat are determined to be bad, replace both components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace. All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com.
If you have any questions, please let me know. I hope you find this information helpful.
Posted on Aug 10, 2009
hunter19_46m
Curtis Sewell
  • 7482 Answers
SOURCE: We have a 10 year old Kenmore elite dryer. We
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
This is a FREE answer, Please rate me
Posted on Dec 11, 2010
Hi. Our belling farmhouse 900g oven is not working as it should. This is regarding the lower left (main) oven. There is no heat being generated despite the indicator light working.
I would guess Since the unit is an electric oven it could have a bad element heating element and that can be determined by testing it with a meter it if the oven on the other side has the same element you could swap the heating element and see if it works and then you'll know you have it that's about all I can suggest for such an unusual oven
Mar 17, 2018 | Cars & Trucks
Unit not generating heat -
More in likely heating element has failed and needs to be replaced...
Mar 04, 2015 | Heating & Cooling
Mr Steam MS Super-1 kW: 10 doesn't generate steam
the first thing the generator should do when you hit the on button is fill. You will hear the water entering the tank. Once the water stops it indicates that the water has reached the water satisfied level, after which you should hear a loud click(your contactor engaging for the heat cycle, newer units will have all three light on the side lit). After this point is you aren't getting any steam after 5 minutes it probably means your heating element may be damaged. It would be best to remove the element at this point from the left side of the unit via 6 bolts and 2 wire leads. Any physical damage on the element such as a pinhole pop, burn mark, melting, or scar will surely prevent the element from heating
Jan 10, 2014 | Mr Steam Electrical Supplies
I have the Mr Steam MS Super 1 T steam unit with the Tempo Plus accessories and auto flush. The unit has worked great for about 2 years but for some reason yesterday the unit light comes on at the...
You would need a multi-meter or voltmeter to trace the power path. Turn on the generator and wait until you hear the water feed solenoid stop. This means the water has reached the satisfied level and the pc board should have sent 24v to engage the contactor. On the actual pc board there is a section label "cont" which is what sends the 24v to the contactor the engage the heating element. Verify that you have 24v on the spade terminals going out to the contactor, if not then you may have a pc board issue. Second possibility is the contactor, if it is recieving 24v and it is not engaging then it's simply a bad contactor. Check the load side of the contactors with the blue wires. Lastly if these two steps check ok, then perform an ohm reading with a multimeter on the actual heating element(with the power off, put your two test leads on the two flathead screws that hold down the blue leads the go to the heating element). If you get an open reading then this may indicate a failed heating element. Pulling the heating element out on the left side panel will confirm any element failure.
Nov 08, 2012 | Mr Steam Ms Super 1e Steam Shower...
The heating works for 1 min. and then it turns off, but the blower is still working
You have a loose connection on your heating element and a defective thermostat heat control-both have a job to do in the generation of heat.Heating element-if it is loose:try thightening the screws holding it down to a terminal(be carefull for this requires safety gloves and unplugging the unit from the mains).Thermostat controls-if defective if will give you wrong settings for the sensor thus shutting off as quickly as it does.
Feb 02, 2011 | Heating & Cooling
Will not run only on gas but will not cool
If it works on gas and NOT electricity then the heating element is not getting power or the heating element is open. The heating element is located on the tubing just aft of where the pilot flame is on the bottom of the copper tube. You should check for power to the heating element and with power off perfom a continuity check on the element. I really do not at this time think you have a heating element problem.
There is a 120VAV element a AND a 12VDC element. The chances of both of these failing at the same time is pretty slim.
There is a note in the manual:
If the gas only pushbutton is depressed the
lamp will illuminate green and the refrigerator
will only operate on the LP gas mode, even if q
120 or 12 volts are available.
Another significant change in the third
generation A.E.S. system is how the 12 volt
heating element mode operates. As with the
first and second generation series, the 12 volt
heating element circuit is energized by the
ignition lock terminal. This terminal receives
its DC voltage from a wire that runs from the
run side of the vehicle’s ignition switch to the
refrigerator’s ignition lock terminal. This
allows the 12 volt heating element to be
energized only when the RV is traveling down
the road.
When the ignition lock terminal is energized
by the ignition key, the printed circuit board
must see at least 13.3 volts DC for a period of
40 seconds before the system will activate the
12 volt DC heating element.
If 13.3 volts is not achieved in this time frame,
the electronics will light the LP gas burner and
the refrigerator will operate on the LP gas
mode.
LOWER THAN 13.3 V.D.C. =LP Operation
If the battery voltage remains low after the
delay cycle, the automatic controls will light
the refrigerator on the LP gas mode and stay
on the gas mode until the printed circuit board
sees approximately 13.3 volts DC to the
terminal block.
For proper cooling on the AC mode, the AC
voltage to the refrigerator should not vary
more than 10 percent from the voltage rating
on the heating element. Heating elements used
in Dometic refrigerators could have a rated
voltage of 110 volts, 115 volts or 120 volts AC.
Because of this, the power requirements for
each differently rated heating element will
vary. For example, if a heating element is
rated for 100 volts, the acceptable power range
would be between 99 to 121 volts AC. If an
element is rated for 115 volts, the acceptable
power range would be between 103.5 to 126.5
volts AC. If the heater is rated for 120 volts,
the acceptable AC power range would be
between 108 to 132 volts AC.
The unit to operate on either AC or DC must have 13.3 volts to the unit. I think this is where your problem lies in that the battery voltage is less than 13.3 VDC
If all of that checks good just repsond here and I will help you. There is still more that can be checked.
Thanks for choosing FixYa.
Kelly
Aug 24, 2010 | Dometic RM2652 Refrigerator
Should I cover my generator while it is running
no possible to over- heat unit the engine needs air to stay cool also the covering can catch fire if u want to protect while out running in elements a make shift tent style cover open on bottom pitched type over top, mine is left out all year my daughters are grown so i use their old little tykes building it fits inside has enough room for air and the building protects it from the elements as well as hiding its appearance
Feb 25, 2010 | Coleman Powermate Premium Plus 6250W...
Motor runs, but no heat generated.
It is most likely the heating element or thermal cut out. That is behind the drum. Remove the front panel. Get to the back panel. take it off. then notice how the belt is. draw if you have to. pop it off. then get gloves on the next step is very sharp and i will be the first to tell you.. you can go to the hospital... anyhow grab the back of the drum and the front then **** up. then you will see heating element and thermostats. you may see the heating element bad, if not then having the unit still unplugged check continuity on the fuses. call me if need any parts or more help. Here
Apr 26, 2009 | Dryers
Dryer runs but will not generate any heat...
If not generating any heat then element is probably burned out- close visual inspection will general reveal break in element coils
If some heat then probably on of the thermostats gone bad. Will power off test for continuity with meter--if no reading replace
Good luck
Sep 05, 2008 | Frigidaire Dryers
Kenmore 63942 Dryer Logo
420 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
