Heating & Cooling Logo
A
Anonymous Posted on May 20, 2010
Amana ap076e portable AC How do I refill with fr...
Amana ap076e portable ac how do I refill with freon
3 Related Answers
Anonymous
  • 254 Answers
  • Posted on Jun 02, 2008
SOURCE: Our Fujitronic FA-900 Portable AC is not running cold like it used to.
Try A.B. May they are out of Kansas City but they will travel up to 90 miles I have heard.
Anonymous
  • 614 Answers
  • Posted on Jul 25, 2009
SOURCE: AMANA AC unit Blows heat in cooling mode
These valves do get stuck. They energize for cool and in the dead postion they heat. Your valve is stuck or not energized. Can you here it click or try to energize. If you dont hee the click you do not have voltage to the valve. The valve is powered thru the defrost board. So that might be your problem. If you have voltmeter. Take the two wires off the valve and turnit on cool you should get 24 volts. If you have 24 volts the valve is bad. If you do have voltage to the valve tap the valve while energized and sometimes this will loosen them up. If the board or valve is bad you will have to call a service tech. Russ There is only so much you can do.
Anonymous
  • 82 Answers
  • Posted on May 11, 2010
SOURCE: Manual for Amana AP076E portable a/c
The manual is by Haier but you will see it is or the Amana AP76E. - http://service.haieramerica.com/documents/User%20Manual%20AP076E.pdf
Testimonial: "Great job!!"
RUST COMES OUT WHEN DRAINING AMANA PORTABLE AC
Cleaning with chlorine bleach will cause a unit to show rust in a very short time. At 4 months there should be no rust flaking
Doesn't get cold
be more descriptive there are several things that can cause it not to get cold.
HOW DO I GET AN OWNERS MANUAL
Please check this link and see if you get the specs.
www.portableacguide.com/unit/?Amana-AP076E
I have an amana self evaporating portable ac for my 500sf condo. I have had to unhook it and roll it outside 4 times to drain it. Lately water is now spilling out the back vent on to my floor. What's the...
It appears to me that because of the small size of your condo, you are just recirculating the humidity in the apartment. The unit is condensing the moisture in the air and then reheating it in the pan causing it to evaporate back into the air. The unit is working properly but the humidity level in your apartment continues to rise. You really need to add a drain from the pan of your portable air conditioner.
Need instruction manuel for amana AP076E
ManualsLib has the manual here: https://www.manualslib.com/manual/5170/Amana-Ap076e.html . Click on the Download button and follow the instructions there if you do not want to go through the manual page by page.
I hope this helps.
I am looking for the attachement that conects the exhaust hose to the ac unit i ve lost mine any suggestions
Try contaxting Amana Directly. www.amana-hac.com
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729 or use some duct tape and cardboard.
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Top Whirlwind Heating & Cooling Experts
Paul Carew
john h
Are you a Whirlwind Heating and Cooling Expert? Answer questions, earn points and help others
