Question about GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR
My kelvinator upright freezer stopped freezing and it just kicks on and kicks right back of what could be wrong with it?
Anonymous
    New Friend:
  • 30 Answers
Start Relay/Overload or Compressor is bad. A bad compressor can make a Start Relay/Overload go bad but the only way to find out if compressor or Start Relay/Overload is bad is to replace the Start Relay/Overload if it starts and stays running you fixed it if Prob. returns in a week or so or if you have the same Prob. after replacing the relay the compressor is bad.
Posted on May 22, 2010
Is a Kelvinator upright considered energy efficient?
freezer --no
every time you open the freezer door , the cold air is dropped to the floor so the unit has to work hard to bring the temp back down same as any up right freezer
fridge --it is as efficient as the rest
May 18, 2018 | Kelvinator Freezers
Kelvinator opal upright freezer is over freezing..is there a temperature control somewhere or what could be the problem?
the problem could be the heater element, bimetal, thermostat, fuse.must open freezer cover and check.
Nov 14, 2016 | Kelvinator Freezers
Deep freeze compressor not kicking on.
Sounds like the relay contacts are staying open.
Jul 29, 2010 | Haier Freezers
Won't freeze
I just had this problem with my wife sister in law if it got lots of ice of snow like build up turn it off and let it defrost it took a matter of may be an hour then it kicked back on and it works fine
Nov 04, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Upright Deep Freeze Stopped Working
the compressor relay is gone For a few dollors you can still save it.
Mar 27, 2017 | Kenmore Freezers
Our 2nd hand Kelvinator upright is running but does not seal the door with a vacuum and is not freezing food anymore
to solve this problem please change the rubber gasket of the door then check the freezing.
Aug 18, 2009 | Freezers
GE 13.7 cu. ft. General Electric Upright Freezer FUF14SUR Logo
801 people viewed this question
Top GE Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Are you a GE Freezer Expert? Answer questions, earn points and help others
