Question about Karcher G 2600 VH Gas Pressure Washer
I hae a archer 87 cc gas pressure washer. I let
I have a Karcher 87 cc gas pressure washer. I let someone borrow it and now when go to start it gas leaks out of the carburator and into the filter as its running. Is there an adjustment that I need to do? If so how and where do I do that. I checked all hoses and nothing is broken or cracked. No gasket issues on the carb. It's coming out of the carb mouth as if it was getting too much gas. Thnks for any help you can give me.
Posted by numar98 on
5 Related Answers
Marty marty
  • 883 Answers
SOURCE: Karcher HD 655 S Does not come up to full pressure
yes...check the check valve. A one-way directional valve, this part is also known as a DUMP valve. It opens when too much pressure builds in the hand wand (when not spraying water) in order to protect the pump, by returning the high pressure to its source reservoir. I suspect the DUMP valve is stuck in open condition (or nearly open).
Posted on Jun 10, 2007
freetek
Steve Allison
  • 5569 Answers
SOURCE: not enough pressure
Speed regulation on small engines is notriously fussy.
Check the linkage to the carburetor and look for a small, light spring.
If there are several holes for one end of it, you may have to try more than one to find the spring tension that lets the engine run steadier than it now does.
If not, then either replacing it or changing the length by shortening or lengthening it will probably be needed.
Posted on Aug 09, 2008
Anonymous
  • 18 Answers
SOURCE: Karcher 2400R
You have a poor signal to the spark plug usually caused by a rusty fly wheel found underneath the pullcord casing. clean it with releasing ajent such as wd 40. common when not in use for a while.
Posted on Sep 19, 2008
Thomas F. Schneider
  • 2715 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
Håkan Sterner
  • 74 Answers
SOURCE: Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
Karcher HDS 601 C Burner not ignited
hi i have a archer has 601 with problems. the boilers not igniting properly and I'm getting a roaring noise and thick white smoke. the fuel sides working fine iv changed the igniter and the coil still the same works when it wants to. any ideas thanks
May 20, 2012 | Karcher Garden
Can not start pressure washer
remove the small bowl attached to the carberator. be careful not to loose the pin for the fuel float. clean the junk out of the bowl. inspect the carb for and remove any junk/gel. reassemble and start.
May 11, 2012 | Karcher 2500 PSI Pressure Washer
Hello I just borrowed a k archer k 2.87 water blaster from a friend and forgot to turn water on before starting motor. Motor stopped after a few seconds and now won't start. Online guide says to change...
Most of the time it is the GFCI on the end of the plug that goes bad. If it were me I would cut off the GFCI and wire in a standard 120v plug. If it still doesn't work after that then there is a good chance that something electric internally has gone wrong which isn't going to be worth repairing.
Oct 24, 2010 | Karcher PSI Electric Pressure Washer
My karcher pressure washer g 2650 oh wont start
Will it start if you pour a small amount of gas in the carb? If so your carb needs to be removed and cleaned.
Jun 30, 2010 | Karcher G 2650 Gas Pressure Washer
I have a Karcher 3000 model G3060 OH WITH hONDA G190
It may be due to some water getting into the engine. I would change the gas and change the oil.
Sep 10, 2009 | Karcher G3025OH Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
HELLO SIR I HVE MY KARCHER WASHER WASHING PUMP HAVING PRESSURE PROBLEM THERE IS NO PRESSURE WHEN I START THE ENGINE
Check the pump. If it's turning you should have pressure unless the pump is leaking . Look it over closely.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 22, 2009 | Karcher G 3050 OHR Gas Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2400R
May 16, 2008 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer leaking oil
Usually electric pressure washers only have oil on the pump, so its very likely that you will find the problem there. I'd say check all the pump seals and if that doesnt solve the problem, you can check to see if all bolts are tight when you close the pump back.
If by any chance you are looking for a new machine and/or parts for your machine, log in to www.roncoshop.com where you will be able to find pretty much anything for your preassure washer.
Apr 07, 2008 | Karcher 2500 PSI Pressure Washer
Karcher G 2600 VH Gas Pressure Washer Logo
59 people viewed this question
Top Karcher Garden Experts
Bruce Robin
Tim Venetis
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
