Question about Sanyo DP42746 42 in. Plasma Television
My sanyo plasma flat screen tv will not come on....
Anonymous
    New Friend:
  • 6 Answers
For what it's worth, you can download the official Sanyo repair manual for this TV (DP42746) at http://www.eserviceinfo.com/downloadsm/43343/sanyo_dp42746.html. I uploaded it here when I had some issues with this TV last year. The solution almost always seems to be to replace the Power Board and the Upper and Lower Y Buffers. The parts and costs (from Sanyo in July 2009) are listed below (NOTE: Sanyo will not ship these parts to anyone but a repair shop):
1. V4 Y-Main (Y-Sustain) Circuit Board (Part # LJ92-01200A, Alt Part # LJ41-02759A) - USD $139.00
2. Upper Y-Buffer Circuit Board (Part # LJ92-01202A, Alt Part # LJ41-02760) - USD $64.00
3. Lower Y-Buffer Circuit Board (Part # LJ92-01203A, Alt Part # LJ41-02761A) - USD $64.00
Sanyo charges USD $10.50 for shipping, which brings the total cost for parts to USD $277.50. From my research, a shop would probably charge between USD $500 and $700 to do this repair. FYI - there is a class action lawsuit pending against Sanyo for this issue. The V4 Y-Main (Y-Sustain) Circuit Boards fail VERY frequently in this TV due to overheating. Hope this helps.
Posted on Aug 07, 2010
Anonymous
    New Friend:
My sanyo flatscreen will not come on. i was watching it last night and it turned off by itself and will not turn on again. any help pls?
Posted on Jun 11, 2010
Sue Billetter
    New Friend:
Dp42410 flat screen tv is not powering on
Posted on Nov 05, 2013
Anonymous
    New Friend:
No, I do not have a solution, but go ahead and post this as a solution since there are no other options for replying to a post, or commenting to say you have the same issue as "solution #1" has done.
Posted on Jun 25, 2010
My Sanyo flat screen tv has a red tint when its on. Can you please help?
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size...
Oct 30, 2016 | Sanyo Televison & Video
How to diagnos a sanyo 50747 flat screen tv
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 13, 2016 | Sanyo DP50747 50 in. Plasma TV
How to clean screen on sanyo plasma flat screen tv
Use windex or any brand of glass cleaner.
Apr 03, 2015 | Sanyo Televison & Video
Scratch on sanyo flat screen tv
The overlay or outer screen on any LCD or Plasma is bonded to and cannot be removed/replaced short of replacing the entire Panel or display unit which needless to say costs more than the set did when new.
If its an older projection set the outer clear screen may be available depending on brand and model number.
Apr 18, 2012 | Sanyo Televison & Video
Was watching the tv and suddenly the screen went black !
my Sanyo DP50747 plasma tv won't turn on. I tried plugging it up to another outlet, but still no power.
Mar 09, 2010 | Sanyo DP50747 50 in. Plasma TV
Safe cleaning of a plasma tv screen
You can purchase a special cleaner i got my mine from staples it is for computer flat screens the guy said it would work on plasmas too.
Dec 29, 2008 | Sanyo DP42746 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
2,916 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
