Hello & Welcome to FixYa
If everything else in the dryer is working fine and it won't heat so it means that the thermal fuse which is located inside the rear panel on the blower wheel housing is bad and needs replacement. Please get back to me if you have any other questions.
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
check
out this electric
no heat
tip...
heatman101
