Lost my software cd of my Fuji Finepix Z10fd how can I find the software to download?
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
SOURCE: finepix viewer
I have searched over time, I never have found that software for free on the net. You can get a CD off eBay for a few bucks
SOURCE: Need Fuji FinePix 2650 Software
Try the fuji 800 number they may be able to sell you a new driver cd. otherwise you can buy a card reader at any camera store that will eliminate the need for software completely for about $15.
SOURCE: software download for j10 fuji
i have a fuji j10 camera my software KA version 2.1f on the cd is to scratched up to work on my pc i have windows 2000 ofice is there ant way i can download it from the internet thanks
SOURCE: Replacing LDC screen on Fuji Z10FD camera
Probably, yes.
Remove the 2 screws on the side,
Remove the 3 screws in the buttom. (2 of which are tri-wing)
Remove the 2 screws in the battery compartment.
Flip out the chrome side (from the front backwards)
Remove the 2 screws underneath the chrome side.
Turn the camera upside down. You can now flip the backcover down (gently lift the cover, both on the mid by the tripd hole and on the side, where the crome plate was) Watch out for the USB connector.
Gently lift the broken LCD out. You need to release (flip up) the tiny white lock on the connector to release the ribbon.
Assembly same procedure, but backwards.
Beware of the flash components. The can give a nasty electrical chock.
