SOURCE: Regrigerator stopped, now freezer too.
It is due to the defrost timer is not working. Once it is replaced, you should be good for another year. The information is given by the repairman. I have this replaced two days ago. The MayTag part number is: 61005988.
SOURCE: Jenn-Air refrigerator is not making ice but it's dispensing water
It can take up to 24 hours for a new ice maker to make ice. Check it tomorrow.
SOURCE: 4 year old jenn-air refrigerator not making ice
first please check you water delivery chanel behiend icemaker, it may freeze up... second you water valve on bottom part on the back is duel( one valve for water dispencer and another one for ice maker) you have to check if it is a power going to that icemaker valve, unplug icemaker inside freezer and plug back now check for power but you have acting fast, ask somebody for help... and third it could be icemaker it self... good luck for additional questions please [email protected]
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
[email protected]
Hi Chubbo,
When you say you checked the Valve, did you check the Supply valve that feeds water to the fridge, or the Solenouid valve that usually casues this problem. Unplug your Fridge and roll it away from the wall. Remove the rear access panel and trace the water supply tubing to the solenoid valve. Lots of time the valve is bad. You can get a replacement Solenoid. at any Appliance part store, or online at www.repairclinic.com.
If you did check that. You can get a coupling that will adapt from the water supply directly to the line coming from the solenouid to pressure up and see if you actually have a flow problem between the solenoid valve and ice tray.
Hope this is helpful to you. Good Day
