Phoenix Gold XS2300 Car Audio Amplifier Logo
A
Anonymous Posted on May 20, 2010
Phoenix Gold Taqntrum 1200.1 My friend Tony adjust the car amp played good for a while then I smelled smoke the amp quit also blowout one of the 12"sub wolfers. I had two amps in the car this one was only running the sub wolfers. I under stand it was switched trebile.
3 Related Answers
Anonymous
  • 8 Answers
  • Posted on Dec 15, 2007
SOURCE: Sub Wiring
if you wire the subs in parallel you would achieve 2 ohms which would theritically double your rms, sadly this isn't the case what with wire resistance and such you might get around 270 rms still not that bad. to wire in parellel you run a positive off the amp to the positive on one sub then run a wire from the first subs negative to the second subs positive the run from the second subs negative to the amps negative and bam 2 ohms but be warned this will put more stress on your amp and cause it to heat up faster. peace bro and best of luck
Anonymous
  • 631 Answers
  • Posted on Apr 23, 2008
SOURCE: phoenix gold xenon 1200.1
Most of them are NE5532s. There's one NJM13700 also.
Anonymous
  • 109 Answers
  • Posted on Jul 17, 2008
SOURCE: hi..phoenix gold x600.1 went into protection
Contact Phoenix Gold at 800.950.1449
Ovr light comes on as soon as I power up my phoenix gold amp
remove speaker wire a amp, terminals
does OVL come on now.???
test 1 done report.
a CAR amp.
no model told at all.
MX or RX xxxxxx numbers.
etc??? nobody can guess what is in your hands
https://phoenixgold.com/collections/amplifiers
1helpful
2answers
A FRIEND OF MY GAVE ME A OLD PHOENIX GOLD QX180.2 AMP IM NOT SURE WHICH IS THE THE POWER OR THE GROUND OR WHICH ONE IS THE BLUE WIRE GO THE ONLY THING THAT I SEE IS B- R B+ SO I GUESS THE RED WIRE IS R ...
I'm not familiar with that amp, but normally the power and ground terminals are larger than the rest. Are B- and B+ a lot bigger than the other terminals? It seems to me that power should be B+, Ground should be B- (although usually they are labled something like +12V and -12V or +12V and GND) and the R is probably for the remote wire (small blue wire that runs to head unit)
I have a Phoenix Gold Octane Amp and 10d subwoofers. My friend took it out last week, and I want to put it back it, but I can't figure out where the power and ground wires go and where the speaker wire...
Ok, when you look at the amp, the power + and ground - will be on one side of the amp with another smaller opening in between them. That opening is for your remote wire from your radio. Without that, your amp will not receive the input voltage to signal it to turn on. The speakers will go into the remaining open holes. Your RCA wires will be on the opposite end of the amp.
My phoenix gold qx 900.1 comes on but goes into protect mode it wont play at all an i wanted to see what could be the problem i had it wierd with 2 kicker cvr 15s at a 1 ohm just runnin off my car battery...
if your amp is not 1ohm stable you will continue to over load it on those kickers you need to take it easy man not go over board with those 15s get you like one 12 man in good box ported or sealed thats all you need man with that amp
I have a phoenix gold ti 1000.2 amp.. this is such a great amp and its hard to find.. the problem is when the bass hit i thought i blew the amp.. no bass comes from the amp anymore but the amp turns on and...
are you sure its grounded good and are you sure the amp is on or do you know for sure its the amp not the sub to see if its the amp just just wire it to an old speaker not a subwoofer and be sure to switch the lpf off
Phoenix gold ms2125 amp blown?
The following is a forum dedicated to PG amps. Someone there will be able to suggest a tech that's familiar with the amp.
http://phoenixphorum.com/
Let me know if you have any other questions.
Crossover
i have lost my manual to the phoenix gold 600.1 xenon amp. i want to set it up by the book can you help me ?
Top Phoenix Gold Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
goneforever.
ADMIN Andrew
ADMIN Andrew
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
