The colors on the screen are not right even when I go into Prefs and change the Color Theme. For example when I change the Color Theme to Red the predominant color on the screen is blue not red. Also the screen is very slow to transition from one screen to another. The battery is fully charged.
SOURCE: Treo 755p Frozen
this happend to me about a month ago, right after this, it went into the hotsync problem. where it would try to connect to hotsyc using the cradle, even though it was not connected. and I basically had no use of my phone unless I actually had it connected to the computer, but asuming that I wasnt going to be able to carry my computer in my purse, there was no way I would be able to use it. after battling it out with support tech from verizon, and the store, palm finally said it was a bad phone and put it on the system that i needed a replacement. so verizon had to honor that. well 5 days later i recieved my new refurbished phone. which was working fine until about 4pm yesterday. I am getting no audio from incoming and outgoing calls, the speakers do work because I can hear audio from videos and ringtones fine. so after the drama of hard reseting again, verizon said that it was a bad phone, and I will be getting refurbished phone #2 with in the next few days. oh and anyone having this problem, after reading like a hundred forums, i came to find out that the connector for the usb port is very sensitive, any kind of moister, for water damage, to even having it in the restroom as you shower, can cause it to get a short in the port that it gives it enough of a charge that it's trying to start up hot sync. however the colored block problem also has to do with your memory card, but same thing, the ports are shorting out just enough to cause somekind of a malfunction. hope this helps
SOURCE: Phone frozen: The screen just shows boxes of red, green, blue and white.
Just had the same problem. When you take the battery out, leave it out for 4-5 minutes. Then when you put it in and reset while holding the on/off red button, it should start. Mind did. Good luck.
Stacy
SOURCE: Error 0.14
Finally found this solution! It is a connection issue at the bottom of
the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will
fix the issue. Do this with the battery out and then pop it in until
you have fixed the issue. Took me a few tries as I was worried about
how hard to do it, but no problem!
