Motorola Mobility Battery Nextel I335/ I465 Clutch 1100mah Logo
A
Anonymous Posted on May 20, 2010
Whats the best baud rate to use on a motorola i465...
Anonymous
Level 2:
New Friend:
  • Expert 133 Answers
  • Posted on May 28, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
133
Questions
Helped
40586
Points
214
Auto baud is usually the best rate to allow for decrepences with the connections
How to unlock a motorola i465 phone
hi codes are the best solution to unlock the mobile.you can get the codes from this site simpleunlocking here they render the codes for all mobile models.they also provide the instructions about how to use the codes in your mobile.
I got a clutch i465 it drop calls and want let me recive text message could i switch to sanyo incarneto or do i have to buy a new phone or get a new phone with out being charge
You will have to purchase a new phone. You can also speak with your carrier to see what they will do for you; maybe they can fix it.
Please rate this answer!
2helpful
Would like to unlock this phone so it can work in Jamaica
The Motorola Locked in which Network in which Country?what is the IMEI Number,You can Unlock it using the Subsidy Code or Unlock code,get the Paid safe code from
Unlocking4u.com and unlock it step by step following the instruction below:then You can use it in any GSM NETWORK in Jamaica Country...
Motorola CLutch i465 Unlocking Instructions Warning : Do not enter any wrong unlock codes on your Motorola CLutch i465 mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola CLutch i465 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola CLutch i465 with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola CLutch i465 is locked to.
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola CLutch i465 ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
Each Motorola CLutch i465 mobile phone has an unique unlock code. You can buy the unique unlock code for your Motorola CLutch i465 mobile phone using the form above.
2answers
Como desbloquearlo
Puede obtener el c?digo de desbloqueo aqu?
http://www.mobile-unlocker.com/motorola-clutch-i465/rs2wp9/ y desbloquear el Motorola i465 Clutch modelo de m?vil.
Listen Read phonetically
1helpful
In tethering my motorola i465 to my laptop to use the phone as a modem, i am limited to 921.6kbs, i need to increase this speed, have tried increasing baud rate on phone, but speed does not change, how do...
dial up is limited by many things. You really should consider upgrading to higher speed, it is the best money you will spend. How much is your time worth? Work on high speed for a week and you could not go back to dial up.
6helpful
Motorola clutch i465
HOW CAN I DOWNLOAD RINGTONES FROM LAPTOP TO MY I465 BOOSTMOBILE MOTOROLA
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
