Any repair to convergence side circuit to any projection TV, need convergence adjustments after the replacement of components. If you wish to get more details about these adjustments, check this link. Hopes it might help you.http://electronicshelponline.blogspot.com/
Pull up previous posts by its left sidebar, or
type in thebrand name and model number to of your set, to its
search box, and press 'Enter' or view it in Mosaic /
Timeslide option.
Hi, For your ease here is a pic of self diagnostic system. Please count the FLASH light blinking and check in the table that what problem is there in your set. Thanks for using FIXYA!
Hi, Its because of Over Voltage of Screen (G2) to Blue CRT. Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines. If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
http://esupport.sony.com/perl/news-item.pl?news_id=24 and try this Sony Picture tube recall http://esupport.sony.com/perl/news-item.pl?news_id=24 Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700
8 Blinks means problem with audio is making set go into protective shutdown Check Audio Amp IC406. You can also make this appear on your screen to show how many times this has occurred or if any other faults are present by pressing the following buttons DISPLAY,CHANNEL,5,VOL MINUS,Then POWER. Hope this helps if you need anything further let me know
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
or ·http://esupport.sony.com/perl/news-item.pl?news_id=24 ·Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
