Question about Nortel Norstar 16-Line PBX Speakerphone
Need to reset the time on a client's nortel phone....
dstrocen
    New Friend:
Press "OPTION" 27. OR Simply press "OPTION" and then us the scroll buttons to scroll through the list of options until you come to TIME/DATE
Posted on Jul 26, 2012
Anonymous
    New Friend:
  • 105 Answers
It depends on which Nortel System your client uses, and which level of software they have in the system. You can try "Feature * * T I M E" (Feature, star, star, 8 4 6 3). If that doesn't work, we'll need more info about the system. Good Luck!
Posted on Aug 05, 2010
Good day. Hoping to get some startup advice. I need to access a new newly reset Nortel 470 switch to configure
you need to reset the setting before you can get the access to the device. Hard reset should be good. once done, plugin to your existing LAN, discover the IP taken via DHCP. configure the device.
Web interface should help you to do quick configuration.
Mar 25, 2015 | Nortel Networks Ethernet Switch...
How to make phone ring for two incoming lines
This is tech side programming known as Configuration, clients usually call in a tech/vendor for this.
You need to find out the password and know how to navigate the system programming, do F**266344 and enter the password.
Navigate to Sets, add line in question , assign ring type.
Dec 10, 2012 | Nortel Lands Phones
Need Help! I have a nortel T7316E, for some
go to tek-tips.com they have a Nortel Norstar and BCM section in there that will get you the help.
Feb 09, 2010 | NorStar T7316E Phone
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
My voicemail on my nortel platinum is locked
You need to reset the password .
Feature 983
enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension
next press the button under the screen with the heading of m box or mail box
next your options are add delete or change
press change .
next enter mail box number
the next step will be to press the reset button
after re-setting the password press the release button . Now open your mail box and enter the default password 0000
Jun 05, 2009 | Nortel T7316E 2-Line Corded Phone
How to remove the old corporate greeting in T7316 Nortel?
Press Feature 983 enter admin password
press AA
press Grtg
press Grtg again
press 1 then ok.
Greeting 1 is usually for day and 2 is usually for night depending on the tech who set it up.
May 17, 2009 | Nortel T7316E 2-Line Corded Phone
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
I have nortel phone ip 2002 i want use for my own carrier i need to reset
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Apr 20, 2008 | Nortel 1140E
Problem with IP phone Nortel 1120E
Try to reset the bandwith of the phone by using the nortel software.
Jul 11, 2007 | Nortel 1120E
Nortel Norstar 16-Line PBX Speakerphone Logo
231 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
Adavoid
Level 1 Expert
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
