608 washer won't fill quickly, all the pies in the
608 washer won't fill quickly, all the pipes in the house were going clunk clunk, then washer would stop and beep all the time, took three hours to fill and then wouldn't wash, going beep beep beep, whats wrong? I don't have an operator manual can you help?
If your washer continues to fill with water and does not overflow onto the floor where is that water going???
The water is siphoning from the machine as fast or faster than it it filling. This is caused by one of two situations both have to do with how the drain hose is routed.
The most common is that the drain is too low. The drain for your washer must first rise above the height of the tub or highest water level before it enters the house drain or drainage sink. This height is typically a minimum of 30". So if you are trying to drain the washer into a low pipe, a short sink or down hill you must first raise the hose or piping to that 30" before it heads down hill.
Second cause is where the drain hose is pushed too far into the house drain. A typical drain pipe in the home has a water trap at the bottom. If you put your washer drain hose down into the pipe too far and contact the water in that trap you will also siphon the water from the machine. The drain hose should hook and be secured to the drain pipe and go inside about 6", that's all that is needed.
You will need a plumber to help with that problem. The washer is designed to turn on and off the water quickly and there is nothing to change the settings.
There is no flow adjustment on the drain on any washing machine, I had a similar problem on my old washing machine, I discovered the problem was the waste water pipe in my house was clogged with scum from detergent residue, I poured liquid plumber where the washing machine drain hose goes into the waste pipe in the house waited for 1/2 hour, then filled the washing machine with hot water, reinserted the drain hose, and wrapped it up with duct tape to prevent further leaks, and the force of hot water uncloged the pipe, .Problem solved
Probably a syphon problem . Check your drain hose to make sure hose is not stuffed too far down drain and air can get between the hose and the drain pipe . If you have tapped the hose to the drain to keep water from comming out the drain pipe , go to home depot or an appliance parts house , and get a syphon break . When a washer fills , but water level doesn't rise in the machine , it's being sucked out by syphoning thru your sewer pipe .
hi it sounds like your pressure valve is on its way out or you have a block in the little pipe best way to see if you have a blok in your pipe is take the top off your washer and find your pie is only thin going in to a round valve take it off and with some water in the drum blow down it if there is bubbles comeing up i would get a new valve hope this helps stuart
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
hmmm..sounds like you may be suffering from back pressure problems. here's what you try first
take about a 5 gallon bucket, and fill it up with water. then let it flow down the drain hole, and then quickly refill the bucket. you are looking for what happens when you have about 25 gallons in 2 minutes going into that hole. If it doesn't go right through, then you might want to have that pipe cored out(in an older home, that's not unusual).
