Question about LG D2526 Gas Dryer
LG DLG 2526W dryer running but no heat
The gas dryer is running but there is no heat. Thus, the clothes are still wet.
Posted by joyhome_pa on
D. Floyd Kolb
  • LG Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
My LG gas dryer model DLG 2555W runs but produces no heat
Gas out. That is the problem. Refill Gas.
Aug 11, 2012 | Cell Phones
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
heatman101
Dec 24, 2010 | LG Dryers
I have LG DLE2101W just installed yesterday. It
I found your manual and learned yours is a GAS dryer... the FIRST check is to be SURE the gas valve to your dryer is OPEN.
There is a Troubleshooting section, but NOTHING about no heat?
Know that LOW gas pressure CAN be a issue too!
I did find this:
"If the dryer no longer heats then the heating element may have failed, but it is not the most common cause. The most common cause for a dryer to stop heating is a blown thermal fuse."
The SECOND Link will be VERY helpful...
More help?
Cause 1 Thermal Fuse
Cause 2 Gas Valve Solenoid
Cause 3 Igniter
LG DLE2101W Support Manuals Warranty More LG
LG Dryer Not Heating
Thermostat
IGNITER
Dec 24, 2017 | LG Dryers
LG DLG8388WM won't heat ...
It could be a clog in the supply pipes inside the dryer itself or a faulty regulator your best bet it to find a local repair shop as dealing with any gas appliance without proper knowledge can destroy your appliance or worse you PS: do you smell gas when it runs if so then it could be the igniter is faulty!
Nov 13, 2009 | LG DLG8388 Dryer
Dryer puts out heat, but clothes are still wet
There may be a clog underneath the lint trap or the exhaust vent may be clogged, if either fails try changing temperature knob to a different setting.
Mar 09, 2009 | LG DLE8377 Dryer
Front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Dec 22, 2008 | LG DLG5932W Gas Dryer
LG DLG 2524W gas dryer
call svc tech under warrenty, also sensor rellies on clothes touching two shiny strips to sense the dryness of the clothes ussaly in front or rear of drier drum or rather back or front wall inside wet clothes short the bars and stalls timer when they are dry does not short bars so sensor knows dryness by resistance of short tilt drier front or back where ever bars are to make shure clothes main tain contact lots of time this cures the promblem
Nov 18, 2007 | LG DLE2532W Electric Dryer
LG DLG 5988 Gas Dryer Does not heat and does not dry
Same problem after 1 year of use. In the past couple of months, the Sensor and Cooling mode light stay on and unit does not dry.
Oct 08, 2007 | LG DLG5988 Gas Dryer
LG D2526 Gas Dryer Logo
822 people viewed this question
Top LG Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
