Question about Canon PIXMA iP3000 InkJet Photo Printer
How to take apart Cannon PIXMA iP3000 to clean the waste absorber
How to take apart Cannon PIXMA iP3000 to clean the waste ink absorber?The message says that the waste ink absorber is full.
Robert Kitaji
    President:
  • 1,335 Answers
You need to replace the ink absorber kit and to completely disassemble the printer to replace the absorber. Attempting to clean the ink absorber is not recommended. Self servicing the absorber can be a very messy operation. I would check with a Canon repair center to see what the cost to have the servicing done by a trained technician. In some cases, it is cheaper to replace the printer.
Posted on May 22, 2010
Waste absorber full. How do we empty?
Resetting The waste ink absorber is almost full message on Canon pixma IP3000.
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice
5: When the indicator lights steady, press RESUME 3 times. The indicator should be orange.
6: Press Power to set data.
Hope it helps.
May 17, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
I have a IP3000 Pixma and the waste ink absorber is full. Where is the waste ink absorber and how do I access it to clean it??
The absorber is at the bottom of the printer but you don't have to clean it. Even cleaning will not make the printer work. All you have to do is reset the ink tank counter. Here is the procedure:
1. Turn off the printer.
2. holding down Resume/Cancel press POWER - indicator goes on green.
3. release Resume/Cancel, continuing to hold down POWER.
4. press button Resume/Cancel 2 times holding POWER, then release all buttons.
5. when the indicator illuminates GREEN - press button Resume/Cancel four times
6. turn off printer pressing POWER.
Aug 05, 2010 | Canon Pixma iP3000 All-In-One InkJet...
Cannon PIXMA iP3000 (Waste ink absorber full)
The waste ink absorber is a pair of pads at the edges of the ink carriage path near the bottom of the printer. Canon will sell you a new set to replace them if you want to d-i-y. Alternatively, you can just rinse the pads until the water runs clean once you open up the printer. Dry the pads well before reinstalling. You need to take the printer apart from the top and get under the ink carriage.
Once you reinstall the pads, you can reset the counter by:
Pixma IP3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
I hope this helps.
(most inkjets waste ink counters are set to hit their fill point at the expected end-of-life of the printer. Additional failures may happen soon.)
May 21, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
What does an error message of waste ink is full mean and how do I fix it. Waste ink absorber is full.
Hi There
Try this is for your printer, but donr forget some time you will need to clean out the waste ink pads that are inside the prinyer.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Apr 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Waste ink absorber is full can i replace or clean this on my cannon pixma ip 3000 printer
Follow this:
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
The waste ink absorber is on the back of printer.There is one cover who can open from the left side.You can replace it or clean it but the procedure is dirty and prepare yourself to get dirty.
Nov 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Cannon printer, model PIXMA MP130/110, waste ink absorber is full
cannon printer pixma mp130/110 waste ink absorber is almost full how do i fix it
Jul 05, 2009 | Cannon Office Equipment & Supplies
How to replace or clean waste ink absorber in Canon PIXMA iP3000
Cleaning or replacing the ink absorber is not for the faint of heart, it's a messy job,wear rubber gloves and old clothes. After the cleaning you still have to reset the counter so it will let you print again, so don't forget that part.
Here is a link to a web page with the full instructions for both procedures.
http://www.polyphoto.com/tutorials/PrintHeadCleaning/CanonCleaningAndReset.html
Dec 25, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Waste ink absorber full on canon pixma ip4000
cannon pixma ip4000 waste ink absorber is almost full what do i do, getting patchy printing, have cleaned and deap cleaned and this hasn't ;helped
Jul 23, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
2,227 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
