To reset camera follow below procedure:
Press MENU, select SETUP, select SETUP1 and select INITIALIZE and press OK to reset DSC-T7 camera.
Hope this info will help you.
Thanks.
To reset your camera use the dial on the top to select auto and that stuff should disappear. Most Sony Cameras have a tiny button behind a tiny hole on the bottom or by the USB port. That is a reset button you might be searching for. Keep in mind that by resetting you will lose all your dates and any internal memory settings. The contents stored in memory stick will not get deleted.
Thank you !!
SOURCE: Sony Cyber-shot DSC-W30 Digital Camera
If you want to reset DSC-W30, press Menu and go to Initialize, select it and press OK
Camera will be RESET and go to factory default settings.
SOURCE: Describe your Sony Cyber-shot DSC-T50 Digital
http://www.camerahacker.com/Forums/DisplayComments.php?file=Digital%20Camera/Sony/E.62.10_on_DSC-T9
Have a look at this website above, this is a VERY common problem, with some Fix's
