Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
I have an Ultra 2 bunn slush machine. One hopper freezes and does not stop even when I turn the switch off and the other one stops chilling? can you help
I have a 2 hopper bunn slush machine.One hopper freezes the second one does not
Posted on May 29, 2010
There are several possibilities that could be causing your problem. However, the most common fault is the solenoid coils which open the valve to allow refrigerant into each hopper. Please see the ports manual at "http://www.partsguru.com/user/Bunn Manual ULTRA2 Illustrated parts 32081.0001.pdf". I think the part you will need is "32133.0001". Before you get carried away though there is one simple thing you can do to prove it is the solenoid coil. In a two-bowl machine there are two solenoids. These are identical. Swap them over and the fault should follow the valve. Here is a site with some useful information about how to do this.http://sites.google.com/site/sencotelsol...
Make sure it's mixed properly. if there is toomuch water, it'll freeze solid. if the mix is too rich, ice will form on the outside of the bowls. you may also have a low refrigerant level.
Posted on Feb 13, 2011
I have come across this problem before. If it keeps freezing in the off mode more than likely you have a faulty main PC Board.
Contact here at Just Refrigeration we do have spare main PC Boards for the Bunn Ultras
www.justrefrigeration.com.au
Mike
Posted on Apr 19, 2011
