Question about LG Vu CU920 Cellular Phone
My phone has frozen - LG Vu CU920 Cellular Phone
Posted by akaylaperry2 on
BenjamineDupont
    Master:
  • LG Master
  • 465 Answers
If you phone hangs, you can use some apps to clear cache. I'm now using LEO Privacy, this feature is very useful in this situation, and the apk size is very small, you can have a try.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Dec 02, 2016
LORETO LACARON
  • 2,071 Answers
This unit is prone of freezing up due to low memory. Check your free space on your phone,make sure you are cleaning memory,by purging cache memory etc. Also when you leave a program actually select"CLOSE" button.Most people close the applications by pressing the escape or red key. This does not close the application has a CLOSE option. For instance if you are in the calendar hit hit menu key and scroll down to the bottom CLOSE is listed. Go through each application and press close. Go into the cache operations clear all categories and hit escape it will say cleaning memory. Go to options - security - memory cleaning - enable it. Then it will now clean memory when idle for 5 minutes. Hope it may helps,feel free to ask whatever the result.
Regards:
VOTIT
Posted on May 22, 2010
My Samsung J3 cell phone is frozen. Any tips to fix this problem?
Hi Gail.
Soft Reset (Frozen / Unresponsive Screen) - Samsung Galaxy J3 V / J3 (2016) View this info if your device is unresponsive, frozen or won't power on or off. ... Simultaneously press and hold the Power and Volume down buttons for 12 seconds or until the device power cycles..
read up more at this link.
https://www.verizonwireless.com/support/knowledge-base-204642
or this link.
Samsung J3 cell phone is frozen Google Search
Jul 03, 2018 | Samsung Cell Phones
The screen is frozen won't do anything
Search Results
    2 Easy Ways to Fix a Frozen Mobile Phone (with Pictures)
    www.wikihow.com > ... > Phones and Gadgets > Cell Phones
    wikiHowHow to Fix a Frozen Mobile Phone. ... If your phone isn't responding to your Power button or screen taps, you may be able to force the device to restart.
    How do I force my phone to reboot or restart when screen is ...
    https://motorola-global-en-uk.custhelp.com/app/answers/detail/a.../72260
    How do I force my phone to reboot or restart when screen is frozen or phone is ... Note: If your phone displays "AP Fastboot Flash Mode" (CLICK HERE to view ...
    iPhrozen? How to reset an unresponsive iPhone - WhistleOut
    www.whistleout.com > Cell Phones > Cell Phone Guides
    Apr 28, 2015 - Don't freak out, there's probably an easy fix if your phone has frozen. First thing's first ... Swipe it upwards off the screen and it should close.
    How To Fix Samsung Galaxy Phone Problems - Gazelle The ...
    https://www.gazelle.com/.../how-to-fix-samsung-galaxy-phone-pr...
    Gazelle
Jan 26, 2016 | Cell Phones
How do you fix yur phone when its frozen??
We need more information, please. What do you mean "frozen"? Do you mean the display isn't responding, or do you really mean frozen, as in iced over? What model of phone are you using?
Apr 29, 2014 | Cell Phones
FROZEN SCREEN
If your phone gets frozen somewhere and cant return home , simply take out its battery and reinsert it , after that switch on your phone and it will starts working as before. And after doing so check for any virus and intursware or corrupted application that caused the frozen , and fix this. thank you regards amir saleem
Nov 16, 2013 | Samsung Instinct Cell Phone
Frozen screen
First you will either need to let your phone die or take out the battery. Afterwards restart it and it shouldn't be frozen. Then go to your settings and find the option to reset.
Oct 10, 2013 | LG P925
What do you do when your concord is frozen
hi there, if your phone is frozen than in this case you need to perform reset your phone. This might help you.
May 08, 2013 | Cell Phones
Frozen A-887 too many attemps frozen
Try removing the battery out of the phone, and putting it back in again. It should be unfrozen when you start it up again. (Battery usually located at the back of the phone)
Aug 30, 2012 | Samsung Cell Phones
Samsung a707 frozen
Hi friend,
I think first you should check whether the phone or the screen frozen, or both of them are frozen, if the phone is frozen,you may try to turn it off for about ten minutes then turn it on, if it still cannot work, you may try to pull the battery out and then restore factory setting if it needs.If the screen is frozen,it may because.....you can visit our website:
www.1010store.com. Hope this can help you!
Aug 20, 2009 | Samsung SYNC SGH-A707 Cellular Phone
Frozen phone
have you checked how much of your phone memory is free. sometimes when there is very little phone memory free, the phone tends to freeze. try to keep atleast 1mb of phone memory free. if even that does not work, backup your data and do a firmware reload. that will surely help.
Aug 18, 2008 | Nokia N72 Cellular Phone
LG Vu CU920 Cellular Phone Logo
147 people viewed this question
Top LG Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Sheldon Dedek
sheva420
sheva420
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
