Krups FLF2 Cordless Electric Kettle Logo
Question about Krups FLF2 Cordless Electric Kettle
Krups kettle leaks at base of pot - Krups FLF2 Cordless Electric Kettle
Posted by wrpz on
Anonymous
    Brigadier General:
  • 3,006 Answers
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
Posted on May 21, 2010
Anonymous
    New Friend:
  • 10 Answers
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is above the heating area. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees so that you have a new high point and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You may have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealants that were:
1. Potable (ie safe since you will be using the water for coffee, tea, and other applications that you ingest).
2. That will withstand heat up to at least 250 degrees Fahrenheit. Remember that water boils at 212 degrees.
I found epoxies that required mixing two compounds but decided that this would be difficult to deal with and apply. In the end I bought "PC Plumbing Epoxy Putty" from PC-Products. This met both requirements and was easy yo use. You take the putty and roll it between your finger just like you did in kindergarten with the clay and make a thin string that you could position in the crevice around the top of the heating area. You may either cover the area where you found the leak or the entire 360 degrees. You will note a somewhat foul smell of the putty. The manufacturers says that it will cure in 3 hours. I found that the smell went away when it completely dried and hardened after 3 weeks!.
I will assume that the same solution is applicable to leaks in other areas of the kettle. I have also found that there are equivalent electric kettles much cheaper than Krups. I would certainly check the construction to see if there is one with less of a chance to develop a leak.
But the bottom line is that it cost me $4. I just finished testing the Electric Kettle and it is fine, not leaking, and the instant coffee did not have any bad smell.
Meir Elazar
Posted on Feb 12, 2011
  • Hawk Wala Jan 16, 2018
    You may want to use high temp sealer. Any auto shop will have high temp gasket maker.
1helpful
RUSSELL HOBBS 18941 KETTLE has slow leak from the bottom of kettle.
They are pretty much a disposable item when they fail. You could try repairing with epoxy putty. Some bases can be screwed a bit tighter.
https://www.google.com/search?q=KETTLE+MOD+18941
Manual
RUSSELL HOBBS 18941
and regarding kettle leaks
https://www.google.com/search?q=KETTLE+MOD+18941+leak+at+base
Krups kettle does not boil water
Sounds like a faulty internal thermostat or it needs to be adjusted.
There seems to be a loose connection between base and bottom of kettle . At first I could press down on the pot and it would start heating . Now I can
If it uses a detachable base to the kettle tank with electrical contacts, sometimes the base or kettle connector must be replaced. You will need the proper tools and wire connectors to be able to replace these parts.
Technically speaking... These are not worth servicing.
Jerry G.
4helpful
My pot has a slow leak. I have tightened all the screws and bolts on the bottom and it still leaks or seeps.
I was successful at fixing my Krups Electric Kettle for $4. In my case the water was leaking from bottom somewhere close to the heating area. I think that a small hole was created in the seal around the heating area in the bottom of the inside of the kettle. One can try to find the general location of the leak by putting a small amount of water in the kettle, place the kettle in a larger pan, and tilt the kettle so that the water is slightly higher than the heating area in one area only noting the position where the water level is the highest. Leave it for a while and check for leakage. If there is none, rotate the kettle a few degrees and look again for leakage from the new area until you find the area where it is leaking. Alternatively you may wish to put a sealant around the entire area, 360 degrees, around the top of the heating area. You will have to remove the strainer first to get your hand in the kettle to apply the sealant.
I went to my local hardware store and looked for sealant that were:
Meir Elazar
3helpful
3answers
The kettle leaks at where teh handle attaches at the bottom
Join the club ---I'm taking ours back this afternoon to BB&B. It's still under warranty and we have the receipt.
My Krups FLF2 kettle leaks at the bottom of the handle
This is a known issue with Krups kettles. If you are a handy person then you can remove the base and use a high temp gasket maker (auto shops have it) to add to existing silicone seal which goes bad after a couple of years.
1helpful
Power cord overheats
The thermostat is not shutting the unit down and cycling it on/off as it should. This will cause the power cord to overheat and it will catch fire. STOP using this unit and either replace it or have it repaired. More than likely cheaper to just replace it.
2helpful
2answers
Krups electric kettle leaks
You cannot fix it when they split like that.
1helpful
The heating element in Krups stainless kettle has burned out
the element is avilb on the web / look under small appliances / or better yet use your model # and google it . the cost of element and shipping may be more than your pot is worth . you be the judge . i would fix it but / it may not be cost efective .. hope this hepls **** ..
Krups kettle explosion???
go to krupsusa.com customer service
Top Krups Kitchen Appliances - Others Experts
Mike
Narseman
Tom Chichester
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
