Question about Sunpentown 2,800 Watt 6.5HP Power Generator
Gasoline Gererator Starts/Runs But Doesn't Generate Electricity, Model 2800 watts 6.5 Hp Checked all wiring, switches, guages, outlets,circuit breaker, & grounds. W/O success, any Ideas, Thanks,
Posted by clark6619 on
My north star 5500 generator starts but does not put out any electricity through the plugs
Check the connections between the alternator (generator) and the regulator/output connectors.
Oct 13, 2014 | Northstar Generator 9 Hp, 5500 Watt,...
Starts and dies right away, intermittent fuel guage
If initial indications sound like a buoy gasoline and extenders and gasoline injection system in the compartments, the problem is in the power feeder wires or in the Bawa-jee or in the combustion chambers of electricity and gasoline. This prevented Mator that it does not appear any kind of Leak of oil and water.
So observed in the case of operating the initial car exhaust fumes if the color was black injection system maintenance problem but if the sky was the color of this is evidence that the oil spill to the combustion chambers.
4db5eaba-57dd-4e28-a8fb-64a64e8b9983.jpg 351746a9-e081-48bb-a651-721784cf6eed.jpg
Feb 26, 2014 | 2002 GMC Sierra 1500
Can I install on a 20 amp circuit with a 15 amp GFCI plug? The unit says 120 v 6 amp max
Jan 2013
1) Yes. With 6 amps.
It is not purely code, but generally not dangerous.
Most household outlets and switches sold at home center are actually rated 15 amp, and should be on a 15 amp breaker. just don't overload.
http://waterheatertimer.org/Color-codewire.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html#heat
2) However if you are running close-to or higher amps than 15 amps, such as space heater (volts x amps = watts), then I would suggest installing 20 amp arc-fault breaker, and protect whole circuit.
http://waterheatertimer.org/How-to-wire-GFCI.html#arc-fault
3) Add comment and say what you do.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 22, 2013 | Malibu ML600TW - Low Voltage Power Pack -...
I turn on compressor starts working but it turns back of agian
If the motor circuit breaker is popping off as you state, it's either bad or the power supply is inadequate. It's not all that rare for the circuit breakers on electric motors to go bad. When they go bad they either won't reset or pop off at lower and lower amperages. Another cause could be that the motor is essentially trying to pull too much electricity through a line that can't handle it. This would be caused by using too many, to long or too small guage extension cords. Always plug the compressor into an outlet and run longer air lines than use extension cords. On some occasions if you are too far from the breaker box and the lines to the outlet are low guage you can get the same affect.
Aug 19, 2012 | Ridgid FactoryReconditioned 12 HP 5Gallon...
The engine runs fine but it fails to generate power
Is the on off switch faulty? Short it across its terminals to see. Also do you have a breaker that needs to be reset on that model? Are both the 240 and 110 receptacles inoperable?
Nov 18, 2010 | Northstar Generator 9 Hp, 5500 Watt,...
Dayton 3W351 generator doesn't generate. Runs fine but no AC output.
The reasons for the generator dose not generate electricity are as follows:
1, the magnetic pole of the generator loses magnetism;
2, the excitation circuit component is damaged or the circuit is broken, short circuit or grounding phenomenon;
3, the exciter brush has bad contact with commutator or the brush frame pressure is insufficient;
4, wrong connection of excitation winding, opposite polarity;
5, poor contact between generator brush and sliding ring, or insufficient brush pressure;
6, broken circuit of generator stator winding or rotor winding;
7, loosening of generator lead wire or poor contact between switch and wire; Fuses, etc.
Jan 14, 2010 | Electronics - Others
Northstar 5500 - no power output, but motor runs fine
Is the Output switch in the "ON" position...the switch is normally on the Outlet manel
Jul 01, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Engine runs but won't generate any electricity
Sometimes the generator loses the magnetic field that allows it to produce power. Do a Google search on "flashing a generator field". There are many ways to do it, but I would recommend doing some reading before trying it. Your "dead" generator could produce hazardous voltage once it comes back to life.
Also, before trying any of this, make sure the circuit breakers on the generator (if equipped) are not tripped.
Good luck and be careful!
Jan 19, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Portable Generator doesnt generate any AC Current
is there a manual reset circuit breaker somewhere?
Dec 21, 2008 | Electronics - Others
Sunpentown 2,800 Watt 6.5HP Power Generator Logo
192 people viewed this question
Top Sunpentown Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you a Sunpentown Electrical Supply Expert? Answer questions, earn points and help others
