First you have be ensure that the microphone is just place in right order. if the mic doesn't right place then it can not connect with it motherboard as a result, it will not work. then if the solve is okay then i understand that the microphone has damaged or became week, for this reason it can not work.
Well, now follow my instructions, you will check the mouth piece by multimeter that means the indicator of multimeter point in X1 place. If your mic is okay then you shall hear a beep sound that means it is ok otherwise not. if not you have to change you microphone means mouth piece. thanks and keep communicate with me.
Hi,when you call someone and they don;t hear you,it means that the mouth piece which is located at the bottom of the phone and allows people to hear is faulty and will need to be replaced. When you replace the mouth piece, people can now hear you.
OK, this is could be one of two scenarios. It could either be the microphone circuit on the cell circuit. Or, this could be just the microphone itself.
It is most likely the microphone itself. This can be repaired. Unfortunately, warranty does not cover water damage, hence, you will need to repair this on your own cost. It will cost around $30 - $50.
The problem is that the mouth piece of your phone is bad
that is why the cannot hear your voice. I advice you get the mouth
piece of your phone replace because it is bad and that is why your
callers cannot hear you.
All you need to do is to change the
mouth piece of your phone and you will see that your callers will hear
after you have replace the mouth piece of your phone.
Meanwhile,
you can get hands free pending the time you will replace the mouth piece
of your phone.
The
problem is that the mouth piece on your phone is
malfunctioning that is why people call or people that calls you barely
hear you. All you need to do is to replace the mouth piece of your
phone and you will see that after the replacement of the mouth piece,
anybody that call you or people you call will hear you clearly.
Just
change the mouth piece as advice and you will see that the problem is
solve. meanwhile, you can be using hands free pending the time you will
replace the mouth piece.
The fault should be from the mouth piece of your phone.
Use a phone screw driver to loose the phone, remove the mouth piece and clean the phone board, especially the mouth piece area of the board. Put the mouth piece back and make sure it contacts the phone board very well. Couple back the phone and test it.
If it still gives the same fault, the I think you need to change the mouth piece completely.
If you cannot get another mouth piece, then I would advice you get a hearphone to receive and make calls for the main time, till you get another mouth piece.
