Question about HP Pavilion dv6000z Notebook
System is wont boot
Blue screen with ***stop: 0x0000008E (0x000001d, 0x00000007, 0xf775F70c, 0x0000000)
This has come up after i tried to use operating recovery discs that came with computer.
Original error message stated that personal settings would not load and no changes would be saved once the system booted. I cant get to hat original error message now.
Posted by jeleazar on
Anonymous
    Guru:
  • 528 Answers
Getting 0x0000008e is surely a signal that your registry is corrupted. What you need to do is to fix 0x0000008e as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don’t fix 0x0000008e, this potential risk will bring you more troubles, Even system crash.
Cause of the problem would be.Mis-deleting registry entries, downloading dubious files, hard shutdown PC etc can also cause 0x0000008e.
Heres how to fix the issue
Download the software fix by clicking here.
Launch it after finishing the installation.
Click “Scan Now” button
Click “Repair Problems” button and fix 0x0000008e.
Posted on May 21, 2010
Anonymous
    New Friend:
My compaq presario sr5237cl has the blue scren of death on it i cant boot nor restore the system .... this occurred after i allowed the system to be updated error *** " stop: 0x0000c1f5 (0x00000000,0x00000000,0x00000000,0x00000000)
Posted on Mar 31, 2011
Bluescreen 0x0000008e (0x000001d, 0x805405d8, 0xeb6f3ds4
- Start window in safe mode And follow these steps
- Update drivers for your hardware.just go to site of your laptop manufacturer Once there enter the model number OR service tag of the laptop then request driver (usually found in the web site's "Support Section"). There you should be able to find all the drivers for your model laptop Most Blue Screens of Death are hardware or driver related so updated drivers could fix the cause of the STOP error.
- Return BIOS settings to their default levels. An overclocked or misconfigured BIOS can cause all sorts of random issues, including BSODs.
If problem still exists, then I will suggest you to get Intel software partner reliable program Reginout to fix your annoying blue screen problem.
Best of luck
Jun 16, 2013 | Computers & Internet
0x0000008E (0xC0000005,0x805D946E,0xF78032FC,0x00000000)
Remove all USB attached devices like drives. You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode). Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates. Uninstall last program(s) that was installed, again in safe mode. To eliminate possible bad RAM. Unplug PC, open case, and remove all RAM. Test one DIMM at time, one slot at a time. Re-install Windows. Clean install works best, but all data will be lost. Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Dec 11, 2012 | Microsoft Windows XP Home Edition English...
Wont boot up blue screen and i have no disks
HI there,
Can you tell what the bluescreen message is?
Can you please capture the 0x0000000 error code.
Thanks!
one thing you can try is to remove the memory sticks (RAM) of the computer and then put it back in and start the computer again.
If you have 2 try them one by one.
Sep 17, 2011 | Dell Studio 17 Laptop
Pc blue screens with 0x0000008e (0xc0000005, 0x807019uf, 0xaa7ff48c, 0x00000000) after reboot goes into safe mode boot option. Selecting xp pc boots normally. repeated reboots pc works fine. But if left...
STOP 0x0000008E errors are usually caused by memory hardware failures and more rarely by device driver issues, viruses, or hardware failures other than your RAM.
Download and run from a floppy or CD MEMTEST86 at
http://www.memtest86.com/
Aug 05, 2010 | Evesham Evolution PC Desktop
Blue screen Dell Dimension C521
This problem occures when ther is an conflict with drivers, so try to updat your Bios from dell web site orm you may try to update the video driver or have an option to replace it and try Try to boot the system safemode and chk if you get the same BSOD if not then its the video drivers
Regards
Samson Ved
Feb 05, 2010 | Dell Dimension C521 PC Desktop
Computer Blue Screen of Death
burn this disk as an .iso and boot from disk. try the recovery options on this disk first, and if nothing then you may be in need of a free OS install. you MUST keep all virus, spyware, and firewall up to date n order to keep your computer safe. free-avg.com does have a great free download.
Good Luck
Mar 12, 2009 | Computers & Internet
Blue screen of death.
Try re-seating the RAM (memory sticks) with the system turned off. Clean out any dust from inside the PC, especially on the CPU fan.
Windows xp home does not boot
Replace the HDD.
You don't want your precious data on that drive.
Nov 08, 2008 | Maxtor Hard Drive
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Toshiba PSA60L-004003
1. Try removing the memory
2. Try removing the hdd (try to use another ide drive)
3. try removing the cdrom
In that order try to remove them clean them, or use a spare, and see if the error pops up again.
Apr 09, 2008 | Toshiba Satellite A60 Notebook
HP Pavilion dv6000z Notebook Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
