Jura Capresso Impressa E9 Espresso Machine & Coffee Maker Logo
A
Anonymous Posted on May 19, 2010
How to repair my jura... - Jura Capresso Impressa E9 Espresso Machine & Coffee Maker
acehead
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 107 Answers
  • Posted on Mar 23, 2015
acehead
Expert
Level 2:
New Friend:
Cheetah:
Answers
107
Questions
0
Helped
102301
Points
113
Hi, I made a video how to fix your Jura step by step, good luck!
http://fixandparts.wix.com/nicknicoloudis#!jura-coffee-machine/c15gy
I have a Jura ENA Micro 9 One Touch coffee machine, I was going to start a cleaning cycle and then Close Cover screen came up, even tho the cover was closed. I tried everything and nothing worked!
If the "Close Cover" screen is coming up on your Jura ENA Micro 9 One Touch coffee machine even though the cover is closed, there may be an issue with the cover sensor or the machine's internal sensors. Here are a few things you can try to resolve the issue:
  1. Double-check that the cover is securely closed: Make sure that the cover is firmly in place and not obstructed in any way. Remove any excess coffee grounds or other debris that may be blocking the cover.
  2. Power cycle the machine: Turn off the machine and unplug it from the power source for a few minutes. Then, plug it back in and turn it on to see if the issue is resolved.
  3. Perform a reset: Some Jura coffee machines have a reset function that can be accessed by pressing and holding down certain buttons. Check your machine's user manual to see if there is a reset function and how to access it.
  4. Contact Jura customer support: If none of the above solutions work, it may be necessary to contact Jura customer support. They will be able to provide you with further troubleshooting steps or arrange for a repair or replacement of your machine if necessary.
Note: Before attempting any maintenance or repair work on your Jura coffee machine, be sure to unplug it from the power source and read the user manual thoroughly.
Leaking steam valve
Jura are a top brand and offer service and repair on their machines. Ask your local Jura dealer for a repair estimate.
Where can I get My Jura machine repaired in Cleveland Ohio
Did you ever find someone to fix your jura in Cleveland ? I'm looking for someone too
Where can I send my Jura z5 for repair?
Which part of the world are you based? Go to www.jura.com, select which part of the world you are based, and it will take you to a local agent.
Otherwise google it
Looking for repair or service manual for Jura E80 auto coffee maker.
Hi Glen
MANUALS & Instruction Books are On Line
The drivers & Books & manuals are more than likely on the manufacturers site.
They usually can be downloaded for currently available devices.
Search their support area for your specific model of device.
Try Google Search for a Manual or PDF File for the specific brand & model number.
Also check these Sites:
www.retrevo.com .... Manuals
www.office.manualsonline.com
I have the F-9. Came home after using the machine this morning and noticed the hot water button light was lit while the machine was off. I tried to start the machine and it isn't doing anything. ...
Hi, Sounds like a sencor on the boiler is faulty. It needs to go into the repair shop. you cant buy parts for Jura. You have to use an autherised repairer. Not many Jura repairers around. Im a repairer based on the sunshine coast Qld. Dazza
Jura F9 repair needed
pls DIY the repair. Instructions are easy to follow: https://youtu.be/Sz3fyg-36JQ
My krups coffee machine comes up with service 8, what does this mean
The Brew Unit needs to be repaired or replaced. We repair Krups
Go to www.hotncold.com Click on Jura Repair. Krups and Jura are made by the same company.
Jura Water Pump
Any luck yet.
Jura parts are hard to gain access to in the US. They'll offer to repair it all day long. But sell you parts.....not likely. There are some internet stores online in Europe that you may have to look at to get parts. Good luck and if you find a good store that will ship to the US, please let me know.
Mike
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
