Question about Lands Phones
I have a Nortel T7208 phone. It shows "Message fo...
I have a Nortel T7208 phone. It shows "message for you" and the light is on but when I open my vm. I don not have a message how do I get rid of this?
Anonymous
    New Friend:
Posted on Jun 07, 2010
T7208 Nortel Norstar phone system - how to retrieve a deleted voicemail?
unfortunately when a message is deleted... it is deleted unless you have a back up
Mar 25, 2010 | NorStar T7208 Corded Phone
How do I listen to by mesasges on a Nortel T7208
To access your voice mail messages either press your open voice mail key (if programmed) or enter feature 981.
Dec 11, 2009 | NorStar T7208 Corded Phone
Message waiting does not show on the LED (but did previously)
Did the messge waiting light work before?
Does the light flash when there is an incoming call?
try this... FEATURE # 8 0 6
this is a code to shut off the Static Time and Date feature on the set. Usually if this feature is turned on, the set does not flash where there is a message.
Well that is one thing, or the port maybe bad, and a technician maybe required to move that phone to a new port on the phone system.
Aug 25, 2009 | Nortel Business Series Terminal T7208 -...
Message waiting indicator light is on but there are no messages
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
Aug 20, 2009 | Nortel Business Series Terminal T7208 -...
Message waiting led stays on even though there are no messages in voice mailbox
Good Luck.
Jul 14, 2009 | Nortel Business Series Terminal T7208 -...
T7208 continually says "message for you" can't seem to clear
Thank you, Feature # 65 worked for me on a nortel T7208
Mar 23, 2009 | Lands Phones
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Jan 21, 2009 | Nortel Business Series Terminal T7208 -...
How can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
Apr 17, 2008 | Nortel Business Series Terminal T7208 -...
Lands Phones Logo
930 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
