Question about Motorola Mobility RAZR V3
Razr phone just fell out of back pocket into toilet. I took of back cover & removed battery. What next?
Anonymous
    Novelist:
  • 152 Answers
Dry the phone, battery, sim card, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs.
Posted on May 21, 2010
Phone fell in water
If it's at the point where the screen isn't working properly, it's dead. If you have some kind of extended warranty, it may cover it, but there's no real way to bring it back from being water damaged, unfortunately.
Jan 25, 2014 | Samsung Galaxy S GTI9000 Smartphone
Two function keys & the 7 key have died the past - Motorola Razr
if u know minor repair remove the cover and key pad clean it and fix it as it is then it works.....it help a lot....
Dec 05, 2009 | Motorola Mobility RAZR V3
My motorola razr fell in the toilet. yes, i know
You might try removing the battery pack and sim card then placing it in an area of warm air flow. If the mineralization in the water in which you dropped it wasn't too high, it might recover after several days. It's worth a try and the price is right-
Nov 12, 2009 | Motorola Mobility RAZR V3
Add toilet shower and sink in attic space-to 4 inch vent passing through attic with minimal replunbing
Using a vent as a drain is not a good idea.The vent prevents backing up due to air pockets in theat section of drainpipe and obnoxios fumes will escape through the shower frain vithe possibility of creating an undesireable odor throughout the home.. Consult with a plumber befor using a vent as a drain, Ther e may be a building code issue. Good Luck, I understand your idea, but, I recommend specialized advice. Good Luc
Nov 03, 2009 | American Standard 2383.014.165 Silver...
Dropped phone in toilet. please please please help. i need my ph.
http://www.fixya.com/support/r3771170-phone_water_damage
Apr 24, 2009 | Motorola Mobility RAZR V3
QUESTION ABOUT MY MOTOROLA RAZAR
remove the back batery cover on the insude next to the batery there is a circle the one have to be white if there is a red color circle that means water damage and you can not do nothing does not mater if you get new baytery the problem is in the board or microchips so you have to get a new one sorry
Dec 29, 2007 | Motorola Mobility RAZR V3
Nokia N70 fell in the toilet
Its better not to use it because even if it be repaired this will not be reliable.
best solution ?
please dont forget to vote if you consider my suggestion helpfull.
Dec 28, 2007 | Nokia 7260 Cellular Phone
Cell phone
if the phone didn't get wet or u can't see a visibly broken screen then ur lcd may still be working, u simply may need to re seat the ribbon cable that connects the lcd by un screwin the 4 screws that hold the display n pryin in open from the mid section of each side then use somthing flat to lift the connector n replacing it pressin firmly.
Nov 26, 2007 | Motorola Mobility RAZR V3
Cell phone
sorry but oncce they get wet they never work the same again
It may come to life if you leave it dry a little while longer but the damage is done
You will find if it starts to work again that all sorts of faults will occur as time goes bye
Nov 17, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Relax
Relax
Thejus Mt
Thejus Mt
Level 1 Expert
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
