Hi! my 5 years old projector acer PD113P after a lamp replacement is not receiving the signal from S-cable nor the yellow rca (video) any more. And also the menu button on the projector isn't working. Lamp is on regularly but the projector doesn't react to input video signals or buttons (menu arrows...) press (my remote control is broken). is it worthy trying to repair it? thanks a lot marco Cortesi
SOURCE: Controls not working
This is apparently a common fault and the unit must be returned to a service centre. Theyll put in a new motherboard for it and unless its under warranty this might actually be more expensive than buying a new unit.
SOURCE: No Signal
i wanna try to change into 75hz, but there is only 60hz available. what should i do? my acer pd1100 projector won't display the pict from my laptop :(...
SOURCE: Reset Lamp Hours Timer
Make sure the main power switch is OFF. Hold the "ON", "MENU", and
"VOLUM -" buttons at the same time and turn the main power switch on.
Keep them held until the yellow power standby light comes on, then let
go. It is done.
This works for Toshiba TDP T-9
SOURCE: acer projector
My Acer PD125projector was working perfectly but has been out of use for 6 months. When I connect it now, I get:- 1. "ACER - Empowering People" screen, then 2. After a short delay the message "The Lamp is approaching the end of its useful life at full power ........." is displayed for a short time, then 3. The initial screen returns, together with a "No Signal" message. After this warm up none of the controls on the actual machine nor the the remote controller, except for the power button, will do anything. What can I do about this?
SOURCE: I need to reset the
Found reset in menu. the first time I turned it on after replacing bulb it would not let me reset, but after I turned it off then back on I was able to do it. Not sure if this was a fluke or not.
