Question about Makita 12V Cordless Impact Driver - 6980FDWDE
Is it possible to replace the batteries in a 12v makita battery pack
  • 'Woody' Parker Oct 14, 2016
    I use a system of 2 parallel 3-cell lithium 17850 - a millimeter thinner version of the laptop cell. rebuild the contact set with epoxy holding the contacts to the holder head . solder . rebuild a charger to charge to 12.6 volts (or less, no lower than 3.8v per cell), - one could use the two other contacts as connections to 'balance' the three 4.2v sets. or just hook up to a source with magnets, etc. stuff foam in open spaces.
B Johnson
    New Friend:
  • 13 Answers
Take it to your local Batteries + Bulbs store and get it rebuilt or replaced. Batteries Plus Bulbs and Battery Store Find Battery for laptop auto...
Posted on Aug 17, 2014
Repair Ahjoshe
  • Makita Master
  • 885 Answers
Unfortunately there are no repairable parts in a battery. Once a battery is dead it's usually best to find a good recycling center for it, most The Home Depot's have one. Makita lists battery 1234 (Part #193157-5) for this tool but it's the old Ni-MH battery. I'd use battery 1222 (Part #192598-2), it's the better Ni-Cd battery.
Posted on Aug 19, 2010
Why does my Makita 6011D cordless drill not work when my charged battery in installed? The battery does work on my Makita saw so I know it is not the battery.
Look inside where the Battery terminals connect.
THey are flat metal springs inside the drills Battery hole.
Make sure the are not compressed down causing them not to touch the battery terminals of the battery.
ALso check the Brushes on the drills motor they may need replacing...
Selvol
Jul 06, 2014 | Makita 6011DW Battery 1500mAh, 12V, Ni-Cd
How to fix bl1830 battery when flashing red to green in charger
Take the liberty to disturb:
Our company is a Shenzhen battery factory, engaged in battery industry for 14 years, in 2010 began to set foot in the tool battery pack accessories industry, the MAKITA 18VBL1830 14.4V BL1430 opening 10.8V BL1013 series battery pack, Bosch 12V lithium battery pack and charger.Milwaukee 12V M12 1.5A 3.0A M12 M18 charger etc..Manufacturers supply quantity of large amount of pricewelcome to 86+15014034610 QQ 47018380 Mr. Miao
Feb 15, 2013 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a makita 6391D cordless drill with 18v ni-cd 1.3ah batteries, just had one battery and charger stolen so have to buy replacements is there any way i can convert it now to lithium batteries if
Replacement MAKITA 6391D battery pack 100% compatible with the original 6391D battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_6391D_power+tool+battery.html
Jul 06, 2012 | Drills
Need cap off makita 9000 battery pack to replace bad cells
Yes, I agree with Wylie Johnson. You should replace a new 9000 battery for youe drill. I found the capacity of your orignal battery is only 1.3Ah. You can get a 3Ah makita 9000 battery. It can last longer in your work.
http://www.drillbattery.com.au/buybattery.php/makita_9000_power+tool+battery.html
Jun 24, 2012 | Makita b9000 battery 9.6v each 1.3ah...
Hi, I have repaired 3 Makita 18V 3Ah Li-Ion batteries recently by removing good cells from other faulty batteries. The Voltages are good now on all 3 and they charge/discharge OK on my own charger but...
You can get a 18V replacement Makita battery for your drill. The replacement one is cheaper. Replacement MAKITA BL1830 battery pack 100% compatible with the original BL1830 battery, high quality, wholesale price.
http://www.drillbattery.com.au/buybattery.php/makita_BL1830_power+tool+battery.html
Jul 07, 2017 | Makita Drills
Switch and bateries
Makita makes two 12V Ni-Cad pod batteries: Battery 1222/2.0Ah (PN: 192598-2) and Battery 1220/1.3Ah (PN: 192681-5). Makita's universal charger (PN: DC1804) will charge any Ni-MH or Ni-Cad pod or stick battery from 7.2V to 18V.
Aug 18, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Replacement 1402 battery
I can't find the 1402 battery listed on the Makita website. What is the tool catalog number and I will find you a bettery that way. You can buy online at Makitatools.com and also they have a locator to find one locally that you can use. Let me know if you need more assistance.
Nov 04, 2009 | Makita 6233DWBLE Factory Reconditioned...
Makita Battery Charger DC18 RA
Maybe your battery is died, you can replace it on
http://www.drillbattery.com.au/buybattery.php/makita_1220_power+tool+battery.html
Jan 20, 2009 | Hand Tools
Makita 12V Cordless Impact Driver - 6980FDWDE Logo
332 people viewed this question
Top Makita Drills Experts
efs_perpends
efs_perpends
epangan29
Mike
Are you a Makita Drill Expert? Answer questions, earn points and help others
