Hi don the error code is a system overload. There are a lot of things that could be causing this temperature short circuit. Inwould take the cover of the unit and see if you can visually see any maybe dust or debri on any condenser coils or fans. If you can't figure it out call an expert.
Here is a link to the manual for your system
http://www.supco.com/images/Seabreeze/New%20Material%202011/NEW%20MULTI-ZONE%20INSTALL%20MANUAL%2012-10.pdf
Peform the following procedure to enter the simulation mode and canceling the code ;-
"#" key ? Interrupt key ?"C" key ? Interrupt key ? 14 ? Start key
Hello Press the PLAY and REWIND keys at the
same time the LCD display shows the fast
rewind symbol together with an S to indicate
that the tape is being erased backward. The
erase function continues until either the
beginning of tape is reached or another function is selected.
if this does not work Send an email to [email protected] or call (800) 644-9525. Please indicate model, serial and detailed description of problem
This is usually a heater fault. The fusing temperature does no reach operating temperature within 25-30 seconds after turning on the power. It could be a blown heating element, or a fault in the heater control circuit.
If your machine is AR-5316, The problem is in the fusing unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
If
these steps doesn't work you must call an authorized serviceman to
check your machine, maybe something is busted on the fusing unit like
thermostat or fusing lamp.
If
I have just downloaded and installed the version 2.20 of the software for the H4 from the Zoom site. It solved my problem and the H4-SD card now shows up in the Finder as expected.
