Question about Waring WMK300 Professional Belgian Waffle Maker
Waffle iron light goes on gut does not heat up...
David Ogawa
    New Friend:
  • 27 Answers
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower. (Turned a bit counter-clockwise.) If the waffles are no longer dark enough at the ready beep, you may have to use manual override by watching the steam and smelling the waffle.
Posted on May 25, 2010
  • David Ogawa May 25, 2010
    Swing
    open the upper half (with handle) and remove the four screws on the
    bottom half. Now close the top and flip. You should be
    able to remove the metal cover from the bottom half.
    The
    fuse is clamped inside the bottom clamshell in silicon tubing near
    the hinge. Do not damage this tubing. Remove the clamp over the
    silicon tubing. Slide the tubing to the side and cut the
    stranded wire close to the fuse. Remove the tubing and cut the
    other stranded wire close to the fuse.
    Be
    careful not to nick the wire when you strip off insulation.
    The
    fasteners (omit plastic covers). Don't forget to reinstall the
    silicon tubing before you crimp! Tighten the clamp over the
    fuse (inside the tubing).
    Reassemble in reverse order.
  • Rich Miller Sep 04, 2013
    The cover doesn't want to lift off. It seems to be stuck under (?) the handle.
Anonymous
    New Friend:
THANK YOU FOR THE HELP, I WOULD NOT HAVE FOUND THE FUSE WHEHE THEY HID IT.
PETE ENGEL
  • Mark Mc Jan 13, 2011
    Excellent instructions. I really appreciate your help.
3 Related Answers
Anonymous
SOURCE: my waffle iron no longer heats up.just a red light
Had the same problem with the WMK300 that others are reporting. Plug it in, hear the click, red light goes on but unit does not heat up. Found the thermal fuse in the white insulation on the bottom unit. Found replacement at Radio Shack (http://www.radioshack.com/product/index.jsp?productId=2102788). Works great!
Posted on Jan 01, 2010
Jim
  • 158 Answers
SOURCE: Waring Waffle Maker no heat
Remove 4 Black Phillips Screws 2 on the front near the handle that flips Use a Good fitting Screwdriver These screws have a thread locker on them. They will strip the heads out if proper care is not used when removing them.Then remove the two screws at the rear of the Iron Just rear of the cooking surface. This will remove the chrome cover on the bottom of the cooking surface exposing the wiring. The thermal fuse is located under a section of insulation under a clamp held in by another Phillips screw.Do not cut or Damage the insulation. Gently pull it back exposing the fuse. After replacing the fuse, insulation ,Clamp and screws check to be sure the iron heats and cycles on and off and the ready light works properly. If it does not cycle the new fuse will blow . Good luck
Posted on Sep 24, 2009
Anonymous
SOURCE: Waring Pro Waffle Maker
Had same issue,found a looks like diode on the black wire leading to the heating elements.It is open circuited.Needs replacing.It is not a diode...maybe a voltage circuit protection device.It is crimped into the black wire under the sleeve clamped down near the handle.Going to radio shack to get a idea,replacement.
Posted on Oct 17, 2009
Owners Manual for White-Westinghouse Waffle Maker model WWM2001
Westinghouse Waffle Iron Operating Instructions ' eHow
www.ehow.com > Home
To that end, Westinghouse offers an electrical waffle iron capable of cooking two waffles at a time. Follow all of the safety instructions in the owner's manual ...
Westinghouse Waffle Iron Manuals - Kitchen Appliances ...
kitchen.manualsonline.com > ... > Kitchen Appliance Westinghouse
Westinghouse Waffle Iron WST3010ZE. Westinghouse OWNER'S MANUAL 2-SLICE BELGIAN WAFFLE MAKER WST3010ZE. Pages: 0 Saves: 0. See Prices
Westinghouse Waffle Iron WST3010ZE User Guide ...
Jan 30, 2016 | Kitchen Appliances - Others
I have a green light and a red. what do they mean?
Red means that it has power. Green means the heating element is on. The green light will cycle on and off as the thermostat controls the temperature. Allow the iron to heat til the green light goes off before adding batter. Watch for steam coming from the iron. When the steam stops the waffle should be done. Keep track of the time that it takes to cook. Experiment with cooking time for the best results.
May 09, 2014 | Toastmaster 277 Belgian Waffle Maker
Toastmaster model 265 user manual
Indicator light shows the the heating element is on. Yes, it should be hot enough when the light goes off. The numbers at the following site may not match but you should be able to find the information that you need.
Feb 18, 2014 | Toastmaster Kitchen Appliances - Others
My Waring Mod# 150 Waffle maker went out in the middle of cooking a waffle and stopped cooking. The red light is on ,but the green light wont come on.
there is a thermostat in the waffle maker if its got over heated the thermosts will have cut out,, or burnt out?
Oct 17, 2010 | Waring WW150 Waffle Maker
I have a Betty Crocker belgian waffle baker and I can't find my manual with the recipes in it - I need the recipe for the belgian waffles that is in the manual.
2 eggs, 2 cups all purpose flour, 1/2 cup vegetable oil or 1/2 cup ( 1 stick) margarine or butter melted, 1 3/4 cups milk, 1 T. granulated or brown sugar, 4 tea. baking powder, 1/4 tea salt.
Heat waffle baker. Beat eggs with wire whisk or hand beater in medium bowl until fluffy. Beat in remaining ingredients just until smooth. Pour about 2/3 cup batter onto center of hot waffle baker. Bake about 5 minuted or until READY light goes off. Remove waffle carefully. About 3 1/2 cups batter.
Makes 10 4-inch Belgian waffle squares.
Nov 26, 2009 | Betty Crocker Kitchen Appliances - Others
My waffle iron no longer heats up.just a red light
Nov 10, 2009 | Waring WMK300 Professional Belgian Waffle...
KitchenAid Proline Waffle Maker doesn't cool down when turned off
You should always unplug a waffle iron because other wise there is a constant direct current to the iron element which if left unattended could cause a fire damage and/or death, any heating element that you cannot break the current(unlike a stove) needs to be unplugged because of the danger and the juice it is also pulling from the power company that you are paying more money for. That goes for all heating elements irons,toasters,fryers,curling irons, even hair dryers **** juice. Let me know if this helps and GOD bless goofballlovers
Apr 23, 2009 | KitchenAid Pro Line¿ Waffle Baker
Waffles stick to both sides of iron
Lightly oil iron prior to heating it up. Use 2 Tablespons of oil in recipe.
Apr 06, 2009 | Kitchen Appliances - Others
Over heating
I would try a new thermostat. I have seen these go defective. Callt he manufacture rep for any spare parts information.
Jerry G.
Jun 22, 2008 | Salton WM5ABLK Waffle Maker
Waffle iron light is on but doesn't heat up
The same thing just happened to my waffle iron. It worked great for a few months and then no heat.
I took it apart and found the problem. Waring used a thermal fuse instead of a thermostat. The fuse is located between the waffle iron and the stainless cover. The issue I saw is that cooking oil (spray) gets in between the cover and griddle and soaks into the insulation covering the thermal fuse. The oil heats up inside there and shorts the fuse.
Replacing the fuse is easy and it is available at Radio Shack for $1.70 (part number 270-1321). It's a 442 degreeF.
The hard part about this job is diassembly and reassembly. I had to take the entire iron apart just to get to the fuse. It took about an hour to take apart and an hour to reassemble. Changing the fuse took 5 minutes.
Good Luck,
Jim
Nov 18, 2007 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
Top Waring Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
