Question about Hayward H-series Electronic Gas Pool Heater H400
I have an ao code and have replaced the vaccum switch and blower vaccum switch and still getting the ao code
Anonymous
    New Friend:
  • 64 Answers
Check the tubing going from the blower to the blower vacuum switch. If there are any cracks, missing, or cut, it will give the same code. Rodents like to chew on this tube. Also, if the blower is not coming on at all, then you will get the same code, and the problem is not with the switch, it is likely in the blower.
Posted on May 22, 2010
Ao error message in Hayward heaters
You didn't indicate exatctly which model you have. But on most the AO error code is :Blower vacuum switch
open error If the blower prover switch does not close after the blower starts the control will
stop the ignition trial go into lockout. The blower will continue to run. Automatic reset is immediate after the switch closes.Check to be sure combustion blower starts
If you don't have your manual you can download one for your exact model at : www.haywardnet.com
Jul 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Spa heater will not ignite. Shows "AO" code.
You need to check and see if you have enough gas supply to run the heater. Older heaters would run on a small gas supply but forced draft are hinkey about how much gas they get. Sometimes this is a gas line size problem but more often than not it will be a gas meter problem. On the face plate of your meter their is a number that tells the size. With a 250 and other appliences in the house you will want a 350 or bigger. The good news is the gas company will upsize this for nothing. If they are supplying more gas your buying more gas. It could be other things but this is the first thing to look into.
May 17, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
I had code AO displayed on my hayward H250IDE. I
Check your wiring again on all the safety devices - Water pressure switch and both Hi- limits in the header.
Feb 19, 2010 | Hayward H Series Pool & Spa Heater 400k...
Blower runs but no ignition then AO error code
Your problem then would be the pick up tubing and/or switch attached to the blower that closes once the blower is on to allow the heater to ignite. Pull the tubing and check it for dust or other debris clogging it and check inside the blower housing for the same. If you can test the switch under operation, you should see it remains open during start up which is why the burners won’t fire. If you do not find any obstruction (if you can, blow some compressed air thru too just to be sure) then you will need to replace the switch.
Jan 04, 2010 | Hayward H Series Pool & Spa Heater 400k...
AO error code
I would have to agree with you concerning the control module.
Jul 31, 2009 | Hayward H Series Pool & Spa Heater 400k...
Code AO is on display. Went throught the
if blower comes on it is calling for heat. i would look at ignitor.it could also be vacuum switch(tube goes to it from blower)however they rarely fail.let me know
Jul 18, 2009 | Hayward 250k Propane IID Low NOx Universal...
Error code AO defined as blower vaccum open
I just had same code. I took off top cover and found the end of the hose attached to the blower was split and not attached securely. Attaching hose solved the problem for me and heater fired up.
Mar 19, 2009 | Hayward H Series Pool & Spa Heater 400k...
Hayward H-series Electronic Gas Pool Heater H400 Logo
829 people viewed this question
Top Hayward Pool & Spa Experts
john h
Marvin
Marvin
Paul Carew
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
