Question about Motorola Mobility H710 Bluetooth Headset
I can hear on my bluetooth but they can't hear me. The bluetooth does not beep when a call comes in
    New Friend:
I can hear using my bluetooth, but the person i'm talking to can not hear me.
Posted on Feb 07, 2011
How do i play music from my phone on my philips micro music system btm2180
1. On the Philips music system, press FM repeatedly until [BT] (Bluetooth) is displayed on the display panel. The Bluetooth indicator flashes blue.
2. On your phone, go to Settings and turn on Bluetooth. Press Scan. Your phone will start searching for nearby Bluetooth-enabled devices.
3. Select 'PHILIPS_BTM2180' on your phone and, if necessary,
enter '0000' (no quotes, all zeros) as the pairing password/key.
After successful pairing and connection with the phone, the Bluetooth indicator on the Philips system will turn solid blue and you will hear two beeps coming from it.
4. Start playing music on your phone and enjoy hearing it from the speakers on your music system !.
Dec 20, 2014 | iSymphony M50 Micro Music System with...
Volume in left earbud is suddenly very low
just do the volume the equalization. Once the Bluetooth is on just click the volume (+) until you hear a beep then click volume (-) until you hear a beep, this should equalize your volume. and give you equal sound from both of you earbud.
Oct 17, 2013 | LG Tone HBS-730 Bluetooth Headset- Black
H730 Bluetooth I can hear people but no one can hear me
You have the 'Mute' turned on. With the H730 turned on, and wearing it, press and hold both volume buttons until you hear a beep, or a voice prompt. Then try making a call. If that doesn't work, repeat the process. Good luck.
Apr 06, 2013 | Motorola Mobility H730 Bluetooth Headset
Cobra 29ltd bluetooth,bluetooth stuck
To disable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a double-beep. You
may hear 1 or 2 single beeps, just keep holding the button until you hear a double-beep. The
Bluetooth light on the CB should remain dark.
To re-enable the Bluetooth link
Press and HOLD the Bluetooth button on the microphone until you hear a single beep. The
Bluetooth light on the CB should blink every 10 seconds.
Sep 25, 2011 | Cobra 29 LTD CB Radio
How to turn on lg hbs 200 bluetooth
  • Press and hold the "PWR/Talk" key on the side of the headset until you hear a beeping noise indicating that the unit has shut down.
  • 2Press the "PWR/Talk" button for 5 seconds. When you hear a short beep from the headset and see a blinking light, the headset is in pairing mode.
  • 3Access your phone or other device's Bluetooth menu, then select the option to search for devices.
  • 4Enter "0000" if prompted for a passkey, then press "OK" to pair the devices.
Jul 22, 2011 | LG HBS-200 Bluetooth Headset
When i plug it in my ps3 the red light comes on but it only stays on for 3 seconds and plus i hear this beeping sound in it i really need help
The beeping is a battery low error.
It is quite possible that the small battery inside of the headset has worn out, will no longer carry a charge and requires replacing!
Mar 16, 2011 | Mad Catz Bluetooth Headset for PS3
I just need a pin number so i can pair my headset to my iphone
Step 1: Set the headset to be discoverable
Turn off the headset.
Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. let me know does thsi help regards golu_fixya
On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000. user_offline.gif
Aug 29, 2010 | Cell Phones
When i try to talk threw my headset the other person cant hear me but i can hear my self talk on it
Could be that the headset has been muted by accident. To unmute, tap both volume buttons at the same time until you hear a tone or kind of beep.
Jan 08, 2010 | Motorola Mobility H710 Bluetooth Headset
Can't hear anything when I used my bluetooth ear piece
When connecting, you must be sure the phone is set to connect to the model of bluetooth earphone you are using, and the connection goes through, Once it makes the connection, it will stal connected until you disconnect it, again using the phone's disconnect key.
May 26, 2009 | Google Android
Motorola Mobility H710 Bluetooth Headset Logo
982 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
