Question about Fujitsu Siemens Celsius 670 (LKN:SWD-670115-031) PC Desktop
Windows xp installation driver problem for megaraid
Posted by pb_biswajit on
Anonymous
    Sergeant:
    Champion:
  • 208 Answers
For all driver problems please see my write up:
http://www.fixya.com/support/r4871388-installing_missing_drivers_free_charge
Posted on May 21, 2010
My LG X200 works with Windows 7. Can I install XP on this model. And if I install XP, the drivers available for windows 7 will work on XP?
The drivers for Wndows 7 most likely will not work on Windows XP.
If this laptop came installed with Windows 7 it may not have Windows XP drivers.
Before you install Windows XP check the LG WEB site for Windows XP drivers for your model laptop. If there isn't any XP drivers then I suggest you stick with Windows 7.
May 20, 2011 | Computers & Internet
Windows 2003 OS installation problem on LSI MegaRAID 320 SCSI CARD so how to install windows. pls advise
use floppydrive to select driver / dump server media & drivers into on folder.use windows unattended cdcreator to create media with drivers
Mar 25, 2011 | LSI Logic MegaRaid SCSI320-4X (320x4128t)...
I have an asus dsbf-d server motherboard installed with two Intel Xeon E5410 Harpertown 2.33GHz processors and 16G ram. I have four 1 TB WD hard drives I want to set in raid 10. I want to install xp 64 bit...
http://support.asus.com/download/download.aspx?modelname=DSBF-D&SLanguage=en-us
Select Windows XP 64 from drop down box. Check for files under SATA (click the plus sign). Have you already tried the LSI MegaRAID?
Nov 25, 2009 | ASUS DSBF-D/SAS Motherboard
Can not install windows server 2003 on Acer Altos G710
Hi! Turn off computer check cable & power cable connection. Windows 2003 Operating System will not support SCSI Drives.
Apr 08, 2009 | Acer Altos G710 Server
LSI Web BIOS won't start?
I have a LSI 8888ELP on a Asus P5Q Deluxe and had the same problem with not being able to access the Web BIOS.
What I found was I could access the Web BIOS if I disconnected the hard drive that plugged into the onboard controller.
Mar 07, 2009 | LSI Logic MegaRAID® SAS 8344ELP (5 Pack)...
Compaq presario v3700 windows xp not instaled
You require Xp Pro that supports SATA - standard Xp is IDE - you must aquire a copy of Xp that is SATA compatible.
Jan 27, 2009 | Compaq Presario C700T Notebook
Drivers for c772tu with windows xp installed
you can install Windows Vista driver. it is comparable with Windows Xp.
Dec 03, 2008 | Compaq Presario 700 470024-192 Notebook
How to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
Feb 29, 2008 | Microsoft Windows XP Professional
Fujitsu Siemens Celsius 670 (LKN:SWD-670115-031) PC Desktop Logo
67 people viewed this question
Top Fujitsu Computers & Internet Experts
Erni Mallari
Erni Mallari
Lee Hodgson
Lee Hodgson
Carlo Barzo
Carlo Barzo
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
