Question about Hotpoint DY46 Style Line Stainless Steel Electric Double Oven
Hotpoint oven, Er89 on lcd panel
Hotpoint oven, Er89 flashes on lcd panel
Posted by dave193 on
electronic & computer repair& servicre
  • Hotpoint Master
  • 12,061 Answers
Http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Cooking/BD32_BD42_DY46_19504417001.pdf
http://appliancejunk.com/forums/index.php?topic=2867.0
OK there are your service and user manuals use the troubleshooting procedures, and you should soon isolate your problem
Posted on May 21, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint BU62 display works but nothing else does.
If the display is flashing auto, then you need to reset it to manual, otherwise oven will not work,
The grill should still work regardless..If you have your handbook, refer to (What if something goes wrong).
If no hand book, type in HOTPOINT USER MANUALS in your browser bar, and follow the links.
Please leave feedback
Dec 02, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Nov 25, 2008 | Hotpoint Ovens
HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Nov 23, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Hotpoint DY46 Style Line Stainless Steel Electric Double Oven Logo
556 people viewed this question
Top Hotpoint Ovens Experts
Michael Thomas
Michael Thomas
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
