Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer motor turns, drum does not
Whirlpool Ultimate Care II top loading washer. I loosened the rear cover to see what might be the problem but can't tell what is supposed to turn (other than the drum). Cannot really see a belt or what the motor uses to drive the drum. The motor sounds to be spinning at a speed that seems proper both for wash and spin but makes an abnormal noise somewhat like a slight grinding or banging This might be a normal sound for a motor that is basically spinning unloaded.
Posted by rafisher9 on
Jeff Meyer
  • 423 Answers
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
Posted on May 21, 2010
Standard washing machine hoses dont seem to fit my Whirlpool Ultimate Care II washer? Do I need an adaptor of some sort....
The Whirlpool Ultimate Care II is an American top loading washing machine and requires different hoses available from Whirlpool.
May 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not drain
Empty turn on side can be a couplke of things. Check drive transmission and water pump for obstruction/binding and for slippage replace parts as needed.
Apr 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
How to take the top off Ultimate Care II
2 screws behind control to loosen control panel. when out panel will hinge back and you should see 2 clips that will pop off with a screwdriver and harness for lid switch. whole cabinet will then come off iff you pull it forward
Oct 23, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer won't cycle through...
The cycle timer may be defective and will need replaced. Hope this was helpful.
Oct 11, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Lint trap
There should be a rectangular flap on the top panel at the rear right of your dryer. the lint filter is in a chute if there is just a hole here then the filter is missing.
Mar 15, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
192 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
