Question about GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
Periodic loud buzzing noise
I have a PDS22SFSBRSS and it has a periodic buzzing sound that is quite annoying. Any fixs? Thanks
Posted by billjaeger on
Jeff Meyer
  • 423 Answers
Two main possibilities:
1.) If the refrigerator has an ice maker but you are not making ice, the solenoid valve will open every hour or so to allow water to fill the ice maker. That valve wears out and makes more noise as it ages. There is a metal rod/bar that can be lifted up to stop the ice maker from cycling.
-or-
The compressor and the associated starter cap may be failing and it can make odd noises when it starts back up after the defrost cycle. Time for a professional to take a look.
Posted on May 21, 2010
How do I stop the buzzing noise when in heating cycle?
BAD IDEA THERE IS A REASON IT IS BUZZING? FIND THAT OUT FIRST
Apr 23, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Annoying sound
Hi Anita
Determine source of Buzz
Speaker --- Computers sound channel Amplifier
Left or Right channel
Can you hear buzz in earphones
Fan --- Speed changes with Temperature - insects or junk hitting on fan
CD --- Player mechanism - CD media left inside
Good Luck
Dec 06, 2013 | Toshiba Satellite Computers & Internet
We Have a GE Model JVM 3670BF001 Spacemaker that started making a buzzing noise periodically when turned on. After a few times of buzzing it quit heating.
You probably had a bad connection now with pop probably separated. You may also have a bad thermal over heat device. one brand is Thermodisk. But you need to know what you are doing. Might be time to replace.
Oct 18, 2012 | General Electric JVM3670BF GE Profile 36"...
Issues with turn signal in my 2001 Oldsmobile Alero. Hazard lights and right/left turn signal emit a very loud buzzing, then gets stuck. It does not work most of the time, or when it does, it buzzes...
Sounds like you have a bad multi-function switch or signal switch they are the same thing.This will fix the cruise control but,your other problem is your hazard warning switch replace it to.This will fix both of your problems.P.S you can get both of these from www.rockauto.com for less than $60.00.
Apr 20, 2011 | 2001 Oldsmobile Alero
THERE IS A BUZZING SOUND THAT COMES AND GOES
the noise is most probably compressor tubing vibrating while the unit is running. when you press against the doors your changing the position of the tubing causing it to quiet down. what you can do to fix it is pull refrig from wall remove unit cover on the bottom and move the tubing around alittle bit then put it back together and see what happens. in some cases unless it makes the noise while your working on it, it may take 2 or 3 attempts to finally get it to stop. additionally if you have copper tubing for the icemaker water line be sure it is isolated as well to help quiet it down.
DO BE CAREFUL when moving the tubing not to cause it to leak refrigerant by bending or moving too much. the noise is an annoyance and not a sign the refrig is about to break down. Thanks Peyton
Mar 16, 2009 | Kenmore Refrigerators
My Wii makes an annoying buzzing sound
I think thats normal. If your really annoyed about it, Play some music that cancels out the noise. I'm sure the in-game music your playing should go over the buzzing noise.
Jun 28, 2008 | Nintendo Wii Console
Buzzing sound from my tv
tv makes a buzzing sound when i turn on the set, than stops.
Dec 10, 2007 | Harsper HP-4200VPM Television
Buzzing Noise and TV picture is yellow
Andy, I'm thinking the buzz is from the deflection coil (yoke) on the neck of the tube or the power supply. Probably not the high voltage as you can hear the "buzz". If it's really that annoying, you can take a length of rubber tubing (no metal) and listen to the buzz coming from the chassis kind of like a stethoscope. STAY AWAY FROM THE HIGH VOLTAGE, please. The yellow picture sounds like a blue chroma failure. A tube can be rejuvinated if need be but that's a job for a pro. Hope this helps.
Oct 30, 2006 | JVC AV-27220 TV
GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
762 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Mike McBirney
Level 1 Expert
gbob59
