Question about Kenmore 74602 Gas Dryer
Gas dryer does not heat - Kenmore 74602 Gas Dryer
Posted by ksspeck on
gfeck956
    New Friend:
    Problem Solver:
  • 6 Answers
After unplugging the dryer and shutting off the gas, check for continuity at the coils, high limit switch, flame sensor, and igniter. You will need to unplug each connection before testing with an ohm meter. Each dryer has a different way of coming apart, some have lower panels and some don't. refer to other on-line troubleshooting guides for proper procedures regarding your model number and make.
Gas is dangerous but you do not need to mess with any gas connections to repair any of these items. You will need to check for lint build up and obstructions. If you find failed parts consider getting other parts (belt, front or rear seals) as well. Vacuum any lint front inside the dryer as this can lead to a fire inside the dryer case.
Posted on Sep 13, 2010
  • gfeck956 Sep 13, 2010
    I forgot to have you check the thermal fuse. It is usually located at the lower part of the exhaust tube. You will have to remove the back of the dryer and probably the lint hose, good time to clean it out.
frank thomas wilson
  • 10,319 Answers
Did you check the entire venting tubes fo an obstruction? The moister sensor will keep the heat off if clogged up with LINT
Posted on Jun 03, 2010
  • frank thomas wilson
    frank thomas wilson Jun 03, 2010
    True about getting a pro unless you are handy in repairing something asthisdryer. Cleaning it out is the one thing nobody does it seemsand this will bring heat back to your dryer is the tubing was never cleaned out before... Once a year is good practice to do cleaning wise
Jeff Meyer
  • 423 Answers
A gas dryer is nothing to mess with if it does not fire up the flame. Pull the lower kick plate off the front of the dryer, unplug the unit and clean out dust/lint build up. Vacuum as needed.
Then after checking that the gas valve that is connected to the end of the gas line that connects from the dryer to the wall, I recommend you get a professional.
Common failures are the pilot / ignition system / thermocouple.
No way to be more specific unless you provide the brand and model number of your dryer.
Posted on May 21, 2010
Gas Dryer has heat at beginning of cycle then no heat.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Whirlpool LGR3624JQ Gas Dryer
No heat/ gas dryer
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 04, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer not heating up
heatman101
May 24, 2010 | GE DPSE810GGWT Gas Dryer
Neptune MDG5500AW Gas Dryer: gas dryer will not heat...
heatman101
May 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Not heating
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 12, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Not getting heat
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
heatman101
May 05, 2010 | LG DLG2532 Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
No heat gas smell
heatman101
Mar 08, 2010 | Estate EGD4400SQ Gas Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
My dryer will not get hot
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Kenmore 74602 Gas Dryer Logo
1,050 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Michael Thomas
Michael Thomas
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
