Question about Carrier 38CKC030 Air Conditioner
38cks is blowing air but it's not cooling
I checked the unit outside and the fan is working, there is ice on one of the two pipes, but the pipe that usually has condensation is dry as a bone.
Posted by poemig on
Anonymous
    New Friend:
  • 34 Answers
First thing, are the filters clean? If so then you have lost some gas from the system and need to find and repair the leak, and put in correct gas charge.
Posted on May 21, 2010
Goldman capf3636b6. Fan outside is running blowing cold air to the outside.Inside is making a humming sound but not running.If I turn it off all of it stopsThere is some ice visible on the pipes
System needs to be thawed out, so turn it off before something else breaks, cause pipes are probably plugged and stopping any movement inside the system, Try using a blow dryer on high heat to help with the thaw out of the pipes with the ice build-up , then leave it off for a couple of hours and then try to turn it on again see if the unit in the house is running or blowing cold air again. Turn it on HIGH...!!!!
I’m happy to help further over the phone at https://www.6ya.com/expert/humphrey_5ffe09540b653dd0
Aug 09, 2015 | Heating & Cooling
High efficiency outside air conditioner does not cool house, seems to for a while but stops. The pipes at the air conditioner are coated with ice so seems to produce cold but does not blow that through the...
Unfortunately, the ice coating isn't normal, in fact, it is an indication that your unit is low on freon or a blockage. But could also mean a few other things.
But about the only thing you can do yourself is make sure that the fan is turning or not.
Jul 07, 2011 | Frigidaire Heating & Cooling
My central air conditioner is making a whistling noise in the inside unit when the compressor is running. It's not the blower because the noise stops after the outdoor unit shuts off. It's also not blowing...
If there is no cooling (meaning no cold pipes and not blowing cold air) then check the outdoor A/C for any visible/obvious issues; breakers not tripped, no debris blocking the outside unit from passing air through it, etc. If all looks ok, you can start checking some things inside of the unit if you feel comfortable doing so. Also, most indoor heaters have a higher speed/rpm for the fan when the cooling kicks on, and the heat runs on a lower speed/rpm.
Hope this helps James
Apr 05, 2011 | Heating & Cooling
Iced up copper pipe... both fans in freezer are not running anymore.. The freezer is a 3 door commercial unit. I had someone here today to fix leak and add Freon. It was working great but when i came to...
Call back who ever fixed the leak, you still have one.
After fixing the leak make sure the drier is changed, system evacuated to at least 500 microns, then do a standing test. Meaning let the unit stand with the micron gauge connected. The unit should hold a vacuum. A slow rise indicates moisture, whereas a rapid rise indicates a leak.
Feb 03, 2011 | Freezers
My airconditioner is not cooling enough what could be the problem
Make sure the outdoor fan is running and check your air filters. Also make sure the indoor and outdoor coils are clean. If all is good then get the refrigerant charge checked.
Jul 18, 2010 | Goodman CLQ36AR49 Air Conditioner
Our air conditioner seems to be working fine yet t won't blow cold air. Its just room temp air actually feels like you're standing in front of a small fan.
check outside unit large pipe should be cool or even very cold small pipe should be warm to touch that will eliminate some questions in order to solve problem also check circuit breaker for outdoor unit see if fan on outdooor unit is running and listen for compressor hum
Jul 02, 2009 | Sunbeam Heating & Cooling
I have goodman 13 seer/ I have power going into the unit and it will not pull in the contact and when i push in the contact the fan will run but not blow in the house and both cooper pipes on the outside...
check power on the 24 volt coil of the contact pushing in the contactor will not make youre blower in the house run only start the compressor and condensing fan on the outside unit. if u do not have 24 volts on the coil of the contactor that could mean a few things high or low pressure switch is open. which this sounds like the problem because you stated the unit starts but both (copper) pipes stay warm this may be cause by no freon in the system. see normally if you push that contactor in when the indoor fan not running u will get really cold big pipe thats called the suction line. check if you have voltage on the coil when unit is calling for cooling if not look at the schematic and ohm the pressure switces if there are any
May 28, 2009 | Goodman CPLT24-1 13 Air Conditioner
The unit is not cooling. have noticed ice on the line in the unit outside.
if one or few pipe may not aproblem may be the thermostat is aet to very low cool anf the fan on low speed or the thermostat is defective also if this icing is growing up means
-1 evaporator need cleaning
- 2 a smll freon leakage
May 04, 2009 | Heating & Cooling
Panasonic Inverter aircon E24DKR icing up inside unit
Yes, if the filters are clean, the coils are clean, and it is still freezing up in cooling mode, then it is low on refridgerant.
Jan 14, 2009 | Carrier 52PQ307 Wall/Window Air...
Carrier 38CKC030 Air Conditioner Logo
385 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
